WeatherDuino Pro2 Compact v5.0_b001 no WIFI connection - Printable Version
+--- Thread: WeatherDuino Pro2 Compact v5.0_b001 no WIFI connection (/thread-1977.html)
WeatherDuino Pro2 Compact v5.0_b001 no WIFI connection - Sun_Dancer - 07-04-2021
After the update v5.0_b001, the Pro2 Compact no longer connects to the WIFI network. If I flash back to V4.3, the connection is restored.
RE: WeatherDuino Pro2 Compact v5.0_b001 no WIFI connection - werk_ag - 08-04-2021
(07-04-2021, 21:58)Sun_Dancer Wrote:  After the update v5.0_b001, the Pro2 Compact no longer connects to the WIFI network. If I flash back to V4.3, the connection is restored.
Hi Sun_Dancer,
Many thanks for the feedback. Indeed, I found a typo mistake on the initial release. Blush
Quote:The initial release has a typo mistake on the Config_Options.h file. On line 312, where it says ENABLE INTERNET, should be ENABLE_WIFI
This typo causes that there is no WiFi connection, and its fixed on the 2021-04-07 update.
Please download the Pro2 Compact software package again.
RE: WeatherDuino Pro2 Compact v5.0_b001 no WIFI connection - bgedward - 08-04-2021
Further to your issue.
I also get compilation errors if I enable 'BROADCAST_DATA' in config_options when testing compilation and have yet to install on my unit.
PHP Code:
C:\Users\xxxxxx\Documents\Arduino\WeatherDuino_Pro2_Compact_v5.0_b001_20210404\WeatherDuino_Pro2_Compact\software\RX software\WeatherDuino_P2ESP8266_RX_v5.0_b001\RX_TX.ino: In function 'void BroadcastData(int, long int, long int, long int, long int)':
RX_TX:536:6: error: 'udp1' was not declared in this scope
      udp1
.begin(UDP_BROADCAST_PORT);
exit
status 1
if I leave broadcast_data disabled it compiles fine but have not deployed to a unit, since i need this flag enable to pass data to my display units.
PHP Code:
      udp1
exit
status 1
I think this can be ignored now and was obviously related.  I have now applied the fix as mentioned in the previous post now of enable_wifi in lieu of enable_internet on line 312 of config_options and now compiles fine.  Time to deploy!
(08-04-2021, 00:22)bgedward Wrote:  I think this can be ignored now and was obviously related.  I have now applied the fix as mentioned in the previous post now of enable_wifi in lieu of enable_internet on line 312 of config_options and now compiles fine.  Time to deploy!
Hi bgedward,
Yes, it is related. Error is fixed on latest Pro2 Compact update.
Thanks for the report.
(08-04-2021, 00:11)bgedward Wrote:  if I leave broadcast_data disabled it compiles fine but have not deployed to a unit, since i need this flag enable to pass data to my display units.
I'm so used to my Wireless Display units that I can't dispense them. The "broadcast data" is a must for me too Wink
