Pro 2 Plus issue - Printable Version
+--- Thread: Pro 2 Plus issue (/Thread-Pro-2-Plus-issue--1826)
Pro 2 Plus issue - Barrow4491 - 07-05-2020
Good morning,
I installed the new software on my WD yesterday and I must say the new forecast app replacing DarkSky is a vast improvement. I also note a flashing green dot on the top left and assume that it to do
with a network monitor?
The only issue is that when I open the screen from the big clock screen saver I can still see the top section of the large digits and the small signal bars at the top of the display are duplicated (photo attached)
While I was at the computer I took the opportunity to alter the “extra sensors” section and update the Rx software
This has caused a couple of issues not present before
The date now shows as 97 05 2020, the colon does not blink, and the touch screen no longer reacts to touch so the sub screens are not available. The green NTP server dot and the version dot are lit and after about 15 minutes the WD displays the red “not receiving data” message. I suspect the Rx is not logging on to WiFi as I cannot see it on my router.
I have re-downloaded the software from your site and used a fresh copy with the same results
I am at a loss as what to do next
