Problem with ESP8266 uploader - Printable Version
+--- Thread: Problem with ESP8266 uploader (/thread-1805.html)
Problem with ESP8266 uploader - WetCoast - 25-03-2020
I just had an error message when I tried to do the ESP8266 Sketch Data Upload. After copying the 'tools' directory to my 'sketches' directory I received the following error when I tried to do the upload:
Arduino: 1.8.12 (Linux), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600" [SPIFFS] data    : /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/RX software/WeatherDuino_P2ESP8266_RX_v3.1_b012/data [SPIFFS] size    : 2024 [SPIFFS] page    : 256 [SPIFFS] block   : 8192 /fonts/ArialBold11LEA.vlw /fonts/ArialBold11.vlw /fonts/NotoSansBold14.vlw /fonts/NotoSansBold14LEA.vlw /icons/WDicon.bmp /icons/tree1.bmp /icons/termometro.bmp /icons/home.bmp /icons/home1.bmp /icons/tree.bmp /icons/moisture.bmp /splash/Pro2Compact_Splash.jpg /splash/WDlogo.jpg /icon50/thunderstorm.bmp /icon50/rain.bmp /icon50/fog.bmp /icon50/unknown.bmp /icon50/hail.bmp /icon50/cloudy.bmp /icon50/clear-day.bmp /icon50/snow.bmp /icon50/lightRain.bmp /icon50/sleet.bmp /icon50/drizzle.bmp /icon50/wind.bmp /icon50/clear-night.bmp /icon50/partly-cloudy-night.bmp /icon50/partly-cloudy-day.bmp [SPIFFS] upload  : /tmp/arduino_build_177758/WeatherDuino_P2ESP8266_RX_v3.1_b012.spiffs.bin [SPIFFS] address  : 0x200000 [SPIFFS] reset    : --before default_reset --after hard_reset [SPIFFS] port     : /dev/ttyUSB0 [SPIFFS] speed    : 921600 [SPIFFS] python   : python [SPIFFS] uploader : /home/gord/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/upload.py usage: esptool [-h] [--chip {auto,esp8266,esp32}] [--port PORT] [--baud BAUD]                [--before {default_reset,no_reset,no_reset_no_sync}]                [--after {hard_reset,soft_reset,no_reset}] [--no-stub]                [--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]                {load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,version}                ... esptool: error: unrecognized arguments: --end SPIFFS Upload failed! This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
I downloaded the 'esp8266fs.jar' file from GitHub and copied it to the same place and everything worked fine.
Just thought you might like to know.
Cheers,
Gord
RE: Problem with ESP8266 uploader - werk_ag - 25-03-2020
Hi Gord,
That error happened because you are using ESP8266 boards manager v2.6.3, while the code was test under v2.4.2
Quote:/home/gord/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/
If you experience any strange behaviour like freezes, revert to v2.4.2 - I don't know if it works stable with v2.6.3
RE: Problem with ESP8266 uploader - WetCoast - 25-03-2020
OK, thanks for the reply, good to know.
As I said, it seemed to work if I used the jar file from GitHub.
Gord
