TX 3.13 Schematic - Printable Version
+--- Thread: TX 3.13 Schematic (
/thread-1799.html)
TX 3.13 Schematic -
atbukc - 11-03-2020
Is a schematic available for the TX PCB v3.13, it's quite different from the v3.12?
Thanks Andy
RE: TX 3.13 Schematic -
werk_ag - 11-03-2020
(11-03-2020, 14:34)atbukc Wrote: Is a schematic available for the TX PCB v3.13, it's quite different from the v3.12?
Thanks Andy
Hi Andy,
You are right, seems I forgot to publish it.
It's here now:
https://www.meteocercal.info/forum/Thread-WeatherDuino-Pro2-TX-v3-13-Electrical-Schematics
atbukc - 12-03-2020
(11-03-2020, 19:11)Werk_AG Wrote: (11-03-2020, 14:34)atbukc Wrote: Is a schematic available for the TX PCB v3.13, it's quite different from the v3.12?
Thanks Andy
Hi Andy,
It's here now: https://www.meteocercal.info/forum/Thread-WeatherDuino-Pro2-TX-v3-13-Electrical-Schematics
Thanks for the update schematic, much appreciated..
Andy
xxDvDxx - 12-07-2020
Thanks Andy
Hi Andy,
Hello, a quick question about this board: I’m looking for install all electronic components, but I don’t have 3K resistors , do u think it’s ok if I put 3.3K value instead of 3K in the R3 Or I must use 2 resistors in serial to achieve that 3K ohm value ?
atbukc - 13-07-2020
(12-07-2020, 10:44)xxDvDxx Wrote: (11-03-2020, 19:11)Werk_AG Wrote: (11-03-2020, 14:34)atbukc Wrote: Is a schematic available for the TX PCB v3.13, it's quite different from the v3.12?
Thanks Andy
Hi Andy,
If you don't use the 3k value then it will affect the accuracy of the battery voltage reported, you could then compensate for this in software but then it would be non standard and you would have it make this change at every update, I would recommend you make a 3k resistor with a series combination..
Andy
xxDvDxx - 13-07-2020
(13-07-2020, 13:17)atbukc Wrote: (12-07-2020, 10:44)xxDvDxx Wrote: (11-03-2020, 19:11)Werk_AG Wrote: (11-03-2020, 14:34)atbukc Wrote: Is a schematic available for the TX PCB v3.13, it's quite different from the v3.12?
Thanks Andy
Hi Andy,
Andy
Hi, I will do it with series combination , thanks for your quick replay and help
xxDvDxx - 14-07-2020
Thanks Andy
Hi Andy,
Andy
Hi , just checking ceramic capacitors but I don’t see in the list the C8 , so it missing from the components list for mistake or on purpose so I don’t have to use it ? ( if needed what value ?)
I didn’t find it
werk_ag - 14-07-2020
Indeed C8 is missing on the parts list, which is now updated.
C8 should be also an 100nF ceramic capacitor.
xxDvDxx - 15-07-2020
(14-07-2020, 19:49)Werk_AG Wrote: Hi,
Ok perfect thanks
