Arduino Nano extra pins? - Printable Version
+--- Thread: Arduino Nano extra pins? (
/thread-1659.html)
WetCoast - 23-03-2019
Another dumb question...
Just received an Arduino Nano that requires me to solder on the pins.
Is the extra 6 pin cluster (I believe it's called the ICSP??) on the top side of the board (2 pins X 3 pins) required for the WeatherDuino TX board? If not I can save some soldering!
Bottom of this photo
RE: Arduino Nano extra pins? -
uncle_bob - 23-03-2019
No, we don't use that programming header as we already have the bootloader installed.
That said, they can be handy if you need to access 5vdc and GND.
