Pro2 compact - Printable Version
+--- Thread: Pro2 compact (
/thread-1539.html)
Pro2 compact -
Xroads - 22-10-2018
Hello.
Is there a mechanical drawing available for the pro2 Compact, or do I have to make one myself
Regds.
Max
RE: Pro2 compact -
werk_ag - 23-10-2018
(22-10-2018, 15:46)Xroads Wrote: Hello.
Regds.
Max
Hi Max,
I'm afraid that isn't available. Writing documentation isn't my strong point.
Would be nice if you could do it.
RE: Pro2 compact -
Xroads - 23-10-2018
(23-10-2018, 00:26)Werk_AG Wrote: Hi Max,
Ok
I'll see what I can do
Regds.
RE: Pro2 compact -
jarekh3 - 23-10-2018
Is it about such a thing?
In a few days you will be ready.
RE: Pro2 compact -
Xroads - 24-10-2018
(23-10-2018, 22:37)jarekh3 Wrote: Is it about such a thing?
![[Image: 28b46013c5b0.jpg]](https://naforum.zapodaj.net/images/28b46013c5b0.jpg)
Jarekh you are my hero
Regards.
RE: Pro2 compact -
jarekh3 - 24-10-2018
If anyone needs a .dxf file, please send me a PM.
Stl is here:
https://www.thingiverse.com/thing:3175181
RE: Pro2 compact -
Barrow4491 - 28-10-2018
Re the Compact Rx,I notice from "jarekh3's drawing there is a RTC module on the rear of the unit. As i was looking at ordering one and installing it in a very compact enclosure (befitting its size) and this would prevent it from fitting, is it absolutely necessary or could I just rely on the ntp server for date and time?
I note that the BME280 is also there and i wonder the accuracy of the temp/RH readings inside an enclosure.
RE: Pro2 compact -
werk_ag - 30-10-2018
(28-10-2018, 05:44)Barrow4491 Wrote: Werk,
Hi Jim,
The hardware RTC its important (unless the software is modified is must be installed). It covers the possibly that you may have the restart the unit in a moment that there is no Internet connection (for any possible reason).
