Pro2 Compact - Printable Version
+--- Thread: Pro2 Compact (
/thread-1508.html)
Pro2 Compact -
Xroads - 23-09-2018
Hello to all.
I have just bought the am, but trying to compile the code it gives me the following error.
WeatherDuino_P2ESP8266_RX_v1.2_b002:51:25: error: ESP8266Ping.h: No such file or directory
#include <ESP8266Ping.h>
I am only using the libraries included, with the from Weatherduino downloaded code.
Where to get that library?
Best regards
Max
RE: Pro2 Compact -
engolling - 23-09-2018
Hi Max,
did you follow the instructions from the Weatherduino Wiki
https://wiki.weatherduino.com/pro2_compact_receiver
and did you install the Arduino libs for the Wemos boards:
https://wiki.weatherduino.com/programming_weatherduino_devices#wemos_d1_r2_mini_isn_t_listed_in_my_list_of_available_boards_how_do_i_add_it
regards,
RE: Pro2 Compact -
Xroads - 23-09-2018
(23-09-2018, 12:47)engolling Wrote: Hi Max,
Hi Engolling
Yes those parts are ok.
Regds
Max
RE: Pro2 Compact -
werk_ag - 23-09-2018
(23-09-2018, 12:34)Xroads Wrote: Hello to all.
Best regards
Max
Hello Max,
I've been checking, and it seems that by lapse I do not include this library in the software package. I have already updated the software package, please download it again.
Just add the missing library to the same folder where you have the other Arduino libraries. The software included in the new package did not change.
Please report back.
Thank you
RE: Pro2 Compact -
Xroads - 23-09-2018
(23-09-2018, 18:58)Werk_AG Wrote: Hello Max,
Please report back.
Thank you
Hello Werk_AG
I'm now getting this following error.
WeatherDuino_P2ESP8266_RX_v1.2_b002:323:8: error: no matching function for call to 'BME280::BME280()'
BME280 bme;
Max
RE: Pro2 Compact -
Hi Max,
Please check if you are using the BME280 library supplied with the software package and not any other.
There is a newer version of the BME280 library that isn't compatible with the WeatherDuino software.
RE: Pro2 Compact -
Xroads - 23-09-2018
(23-09-2018, 21:38)Werk_AG Wrote: Hi Max,
Thanks Werk_AG
That did it.
Regds
Max
RE: Pro2 Compact -
