Help with UVM30A - Printable Version
+--- Thread: Help with UVM30A (/thread-1316.html)
Help with UVM30A - Barrow4491 - 19-01-2018
(24-11-2017, 05:34)Werk_AG Wrote:
(24-11-2017, 05:22)Barrow4491 Wrote:  Werk,
All working now thanks: I have a diary note to change these settings in future Rx software upgrades. Now I am going to design a new housing for my UVM30A sensor.
Taking note of any personal changes on the software is a good pratice. However, regarding this matter, possibly any new software release will keep those values by default. They may not be the best for everyone, but are a good starting point.
I have completed my new housing for the VM30A but cannot get any reading from it. Replaced the sensor, checked the wiring etc but to no avail.
I have attached my Tx and Rx config files in case i have missed something;
WeatherDuino Pro2 PLUS RF Receiver - Version: 4.1 b008 //          Start of user configurable options // -------------------------------------------------------------------------------------- // If you need help about any of the user configurable settings, please first do a search // at the WeatherDuino Pro2 support forum. If you don't find any relevant info, then post // a new thread. // // -------------------------------------------------------------------------------------- //   Define Name and ID's for this weather station // -------------------------------------------------------------------------------------- const String WeatherStation_Name = "TSV NORTH WARD"; // Put here your Weather Station name #define Station_ID      0xA1    // Station_ID, use the same value in all TX units #define Relay_ID        0xA3    // Relay_ID,   use the same value in all WD units // -------------------------------------------------------------------------------------- //   Define your Weather Station location. Use decimal format for Latitude and Longitude // -------------------------------------------------------------------------------------- #define LATITUDE      -19.255    // Put here your Station latitude in degrees North (always use 3 decimal places) #define LONGITUDE     146.819    // Put here your Station longitude in degrees - minus for West (always use 3 decimal places) #define ELEVATION     55       // Put here your Station height above sea level in Meters (no decimal places) // -------------------------------------------------------------------------------------- //   Define rules for Auto Summer Time Display, and clock adjustment // -------------------------------------------------------------------------------------- #include <Timezone.h> // Example for Australia Eastern Time Zone (Sydney, Melbourne) // TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours // TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours // Timezone myTZ(aEDT, aEST); TimeChangeRule aEDT = {"AEST", First, Sun, Oct, 2, 600};   //Queensland Summer Time -  "UTC + 10" or GMT + 10 Timezone myTZ(aEDT, aEDT); // -------------------------------------------------------------------------------------- //   Define Interface Language // --------------------------------------------------------------------------------------       #include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end                              // Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL // -------------------------------------------------------------------------------------- //   Define Roll Over Hour for Meteorological Day // -------------------------------------------------------------------------------------- #define MeteoDay_HStart 9    // Use values from 0 to 23 // -------------------------------------------------------------------------------------- //   Define Display Backlight TimeOut // -------------------------------------------------------------------------------------- const byte  BackLight_Timeout = 100;   // Timeout for display backlight in minutes (1 to 255). 0 = Always ON #define Use_ScreenSaver          1    // Instead of turn off TFT backlight show a big clock screen. 0= No, 1= Yes // -------------------------------------------------------------------------------------- //   Define data display units // -------------------------------------------------------------------------------------- #define Date_Time_Format  0    // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd #define Temp_Display_Unit 0    // 0 for ºC, 1 for ºF #define ATM_Display_Unit  0    // 0 for mBar, 1 for inHg #define Rain_Display_Unit 0    // 0 for mm, 1 for inches #define Wind_Display_Unit 3    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots // -------------------------------------------------------------------------------------- //   Define the type of your Barometric Pressure Sensor // -------------------------------------------------------------------------------------- #define Barometric_Sensor  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180 // -------------------------------------------------------------------------------------- //   Define the type of your inside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define InsideTH_Sensor  0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31 // -------------------------------------------------------------------------------------- //   Fine adjusts for Inside Temperature and Barometer // -------------------------------------------------------------------------------------- const int   TemperaturaInt_offset =   0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC) const float pressure_offset       =   0;   // Pressure Fine Adjust in mB // -------------------------------------------------------------------------------------- //   Define the type of your outside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define MainOutTH_Sensor 0   // 0 for sensor type SHT31, SHT21 or HTU21D, 1 for sensor type SHT1x or DHT22 // -------------------------------------------------------------------------------------- //   Define Wind Speed and Wind Gust resolution // -------------------------------------------------------------------------------------- // This setting only have effect when the software is used in Davis VP emulation mode #define VP2_WindRes     1  // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h                             // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h                             // WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,                             // but also limits both of them, to a maximum reading of just 91.8 Km/h                             // If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).                             // Weather Display users should set this option to 0 - Standard Davis wind resolution   // -------------------------------------------------------------------------------------- //   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers) // -------------------------------------------------------------------------------------- #define WindSpikeControl 1   // 0= Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define the source of your main outside sensors // -------------------------------------------------------------------------------------- // ---- If you are using just one TX board, the source for all items should be equal to your single TX Unit ID (most likely zero). // ---- Define the source of your main Temperature / Humidity sensor #define TH_OutUnit       0   // 0= Temp/Hum sensor connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Temp / Hum // ---- Define the source of your Main Wind sensor #define WIND_OutUnit     0   // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Wind Speed & Dir // ---- Define the source of your main Rain Gauge #define RAIN_OutUnit     0   // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Rain Gauge // ---- Define the source of your main Solar Radiation sensor #define SR_OutUnit       0   // 0= Solar Radiation sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // ---- Define the source of your main UV sensor #define UV_OutUnit       0   // 0= UV sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // -------------------------------------------------------------------------------------- //   Define the type of your Solar Radiation device // -------------------------------------------------------------------------------------- #define Solar_Sensor     2   // 1= Solar Cell "Pyranometer", 2= Apogee SP-110 Pyranometer, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor                             // ---- Support for sensor type 4 is experimental (type 4 is a PAR sensor) // -------------------------------------------------------------------------------------- //   Define the type of your UV device // -------------------------------------------------------------------------------------- #define UV_Sensor        1   // 1= UVM-30A, 2= VEML6075, 3= Reserved #define UV_Transmission 95   // UV Transmission percentage of UV sensor cover material. // -------------------------------------------------------------------------------------- //   Extra Sensors Settings and Mapping // -------------------------------------------------------------------------------------- // ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used. //      Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1 // // ---- Source 0 means TX unit0, 1 means TX unit1... // ---- Source 6 (Reserved) // ---- Source 7 is for BIOS Sensor (Only Temperature is shown) // ---- Source 8 is for Air Quality Monitor. 0= Temperature/Humidity, 1= Dust Density/AQI // ---- (AQI sensors can be mapped to any position, but should be mapped in sequence, Temperature/Humidity always first) // // ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units) // ---- Example: // ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6     //#define ExtraSensors_Source { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{8,1} } //               {0,0} - First extra sensor (ES0), will be sensor 0 from TX unit0 //               {0,1} - Second extra sensor (ES1), will be sensor 1 from TX unit0 //               {1,0} - Third extra sensor (ES2), will be sensor 0 from TX unit1 //               {9,9} - Fourth extra sensor (ES3), not used - not mapped //               {9,9} - Fifth extra sensor (ES4), not use - not mapped //               {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor //               {8,1} - Seventh extra sensor (ES6), will be Dust Density / AQI index from the Air Quality Monitor // //-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6     #define ExtraSensors_Source { {9,9},{9,9},{9,9},{9,9},{9,9},{8,0},{8,1} } // ---- Define personalized names for each Extra sensor. Attention, 8 chars maximum // ---- There is no need to define a name for the Extra Sensor mapped to the Dust Density / AQI index data //                   Max. Size  [--------] const char ESname_1[] PROGMEM = "-";           // 8 chars max const char ESname_2[] PROGMEM = "-";           // 8 chars max const char ESname_3[] PROGMEM = "-";           // 8 chars max const char ESname_4[] PROGMEM = "-";           // 8 chars max const char ESname_5[] PROGMEM = "-";           // 8 chars max const char ESname_6[] PROGMEM = "Dust TH";     // 8 chars max const char ESname_7[] PROGMEM = "-";           // 8 chars max // -------------------------------------------------------------------------------------- //   BIOS soil moisture sensor settings // -------------------------------------------------------------------------------------- // ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID #define BiosSensor_ID 0   // Device ID in HEX format, or 0 not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Settings and Sensors Mapping //   (The mapping logic is the same than used with the Extra Sensors) // -------------------------------------------------------------------------------------- // 0 = Soil Leaf Interface not used // 1 = Soil Leaf Interface connected to a TX unit #define SoilLeaf_Interface  0   // 0, 1, // ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source // ---- For BIOS Soil Temp / Moisture use 7 as source // ---- To disable use 9 in both fields //                                 S1    S2    S3    S4 #define SoilTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} } #define LeafTempSensors_Source  { {9,9},{9,9},{9,9},{9,9} } #define SoilMoistSensors_Source { {9,9},{9,9},{9,9},{9,9} } #define LeafWetSensors_Source   { {9,9},{9,9},{9,9},{9,9} } // ---- Define personalized names for each Soil and Leaf sensor. Attention, 8 chars maximum //              Soil Max. Size  [--------] const char SSname_1[] PROGMEM = "-";            // 8 chars max const char SSname_2[] PROGMEM = "-";            // 8 chars max const char SSname_3[] PROGMEM = "-";            // 8 chars max const char SSname_4[] PROGMEM = "-";            // 8 chars max //              Leaf Max. Size  [--------] const char LSname_1[] PROGMEM = "1";            // 8 chars max const char LSname_2[] PROGMEM = "2";            // 8 chars max const char LSname_3[] PROGMEM = "3";            // 8 chars max const char LSname_4[] PROGMEM = "4";            // 8 chars max // Define VWC calculation method // Method 1 applies only for VH400 soil moisture sensor // // METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer // at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml // // METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) . #define VWC_CalcMethod 1 // Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface // Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry) //                                                  ADC1  ADC2  ADC3  ADC4   const uint16_t AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts const uint16_t AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 }; // -------------------------------------------------------------------------------------- //   Broadacasting settings for Wireless Display Units // -------------------------------------------------------------------------------------- #define Relay_Data       1   // 0= Disables Data Relay, 1= Enables Data Relay // -------------------------------------------------------------------------------------- //   Davis compatible Data Logger Settings // -------------------------------------------------------------------------------------- #define Logger_Enable    1   // 0= Disable 1= Enable byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30) // -------------------------------------------------------------------------------------- //   Define type of your Weather Software // -------------------------------------------------------------------------------------- #define WeatherSoft      0   // 0= CumulusMX, 1= Any other (Cumulus 1, WeewX, Weather Display, etc.) // -------------------------------------------------------------------------------------- //   Easyweather format data Output // -------------------------------------------------------------------------------------- #define Easyweather_Out  0   // 0= Disable (defaut) 1= Enable // -------------------------------------------------------------------------------------- //   Internet Settings // -------------------------------------------------------------------------------------- #define Enable_Internet     1                       // 1= Enable Internet connection, 0= Disable // ---- NTP Settings ---- #define Enable_NTP          1                       // 1= Enable Sync time with NTP servers, 0= Disable // NTP Servers: #define timeServer "pool.ntp.org" //#define timeServer "time.nist.gov"                 // ntp1.nl.net NTP server //#define timeServer "80.96.196.58"                  // timp.mcsi.ro #define timeServer "193.79.237.14"                 // ntp1.nl.net NTP server // ---- Weather Wunderground Settings ---- #define Enable_WUupload     1                        // 1= Enable upload to Wunderground, 0= Disable #define WUupload_period     4                        // Period in minutes between uploads to WU (Should be >= 3 minutes, if less defaults to 4 minutes) #define WUupload_InTemp     0                        // 1= Enable upload of Inside Temperature / Humidity, 0= Disable // ---- Air Quality Monitor - Upload to ThingSpeak Settings ---- #define Enable_AQMtoThingSpeak   0                   // 1= Enable, 0= Disable // ---- Web Server Settings ---- #define Enable_WebServer          1                  // 1= Enable 0= Disable #define WebServer_port           80                  // WebServer port (default 80) // -------------------------------------------------------------------------------------- //   Enable / Disable GPIO routines - General Purpose Input / Output ports // -------------------------------------------------------------------------------------- #define UseGPIO  0   // 0=Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define display order of data screens on the TFT //   Use sequentially numbers from 1 to 4. Use 9 to prevent a particular data screen to be shown // -------------------------------------------------------------------------------------- #define ExtraSensors_Data 3 #define SoilLeaf_Data     4 #define AirQuality_Data   1 #define TXinfo_Data       2 // -------------------------------------------------------------------------------------- //   Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- #define TestMode    false    // false= Normal working mode, true= Test mode only (no logger, no usb connection) /*************************************************************************************     Hardware Settings *************************************************************************************/ // -------------------------------------------------------------------------------------- //   Define PCB Version Number // -------------------------------------------------------------------------------------- //                              Take particular attention to this setting. //                              Your system may not work properly if you define a wrong pcb version number. //                              In case of doubt check what is printed in your pcb. #define Board_Version   13   // PCB version number, without the decimal point Ex: 1.3 = 13 (integer number) // -------------------------------------------------------------------------------------- //   Define your Display type // -------------------------------------------------------------------------------------- #define DisplayType     3    // 1= LCD 20x4, 3= TFT 320x240 ILI9341 // -------------------------------------------------------------------------------------- //   Define LCD I2C address // -------------------------------------------------------------------------------------- // Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display // Default address will work most of the times! #define LCD_I2C_Address     0x27   // -------------------------------------------------------------------------------------- //   SHT31 I2C Address - Default address will work most of the times! // -------------------------------------------------------------------------------------- #define SHT31_address       0x44       // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Presure Sensor Address (no need to change) // -------------------------------------------------------------------------------------- //#define BMP085_ADDRESS    0x77       // I2C address of BMP085 or BMP180 // -------------------------------------------------------------------------------------- //   Debug helper // -------------------------------------------------------------------------------------- //#define PRINT_DEBUG_NTP_UPDATE    // Prints to serial monitor messages related to sync time with NTP server //#define PRINT_DEBUG_WU_UPLOAD     // Prints to serial monitor messages related to Weather Underground upload. //#define PRINT_DEBUG_TS_UPLOAD //#define PRINT_DEBUG_VCHECK //#define PRINT_DEBUG_TCP_SERVER //#define PRINT_DEBUG_AURIOL //#define PRINT_DEBUG_BIOS // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
WeatherDuino Pro2 Universal TX - Version: 4.0 b002 //           Start of user configurable options // -------------------------------------------------------------------------------------- // -------------------------------------------------------------------------------------- //   Define ID and TX unit number // -------------------------------------------------------------------------------------- #define StationID  0xA1    // Must be equal to your RX Unit (Value from 0x00 to 0xFF)   #define UnitID        0    // If you use only one TX unit define it as UnitID = 0                           // For a second TX unit, define it as UnitID = 1 // -------------------------------------------------------------------------------------- //   Define type of Temperature / Humidity sensor used as Sensor 0 and / or Sensor 1 // -------------------------------------------------------------------------------------- #define TH_Sensor0  1      // [SENSOR 0] - 0 for SHT2x sensor, 1 for SHT31 sensor, 2 for HTU21 sensor, 9 for Not Used #define TH_Sensor1  9      // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used // -------------------------------------------------------------------------------------- //   Define which Temp / Hum sensor controls the fan, and threshold values // -------------------------------------------------------------------------------------- #define FanControlSensor  0      // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan) #define fanOn_HiTemp     38      // RS Fan turn on when outside temperature is >= than this value (ºC) #define fanOn_LowTemp     2      // RS Fan turn on when outside temperature is <= than this value (ºC) #define fanOn_LowWind     1      // RS Fan turn on when Wind Average is <= than this value (m/s) // -------------------------------------------------------------------------------------- //   Define type of Wind Speed sensor. See below for allowed types // -------------------------------------------------------------------------------------- /* --- Fine Offset Anemometers --- Use 1O for standard FO anemometers Use 11 for FO anemometer modified with 1 hall effect sensor --- Inspeed Anemometers --- Use 20 for Inspeed Vortex, digital 8 pulse revolution anemometer Use 21 for Inspeed Vortex, hall efect sensor Use 22 for Inspeed Vortex, read switch sensor --- Davis Anemometers --- Use 30 for Davis 6410, 7911 anemometer --- Novalynx Anemometers --- Use 40 for Novalynx, model 200-WS-02F --- Environmental Measurements Limited --- Use 50 for EML, model WSD1 --- Didcot Instrument Company --- Use 60 for DIDCOT, model DWR205 --- Vector Instruments --- Use 70 for Vector Instruments model A100LK Use 71 for Vector Instruments model A100L2 Use 72 for Vector Instruments model A100R */ #define WSpeedSensor_Type 30             // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- //   Define type of Wind Direction sensor // -------------------------------------------------------------------------------------- /* --- Fine Offset Wind Vane --- Use 1O for standard FO wind vane --- Analogue Wind Vanes --- Use 20 for any 5V analogue wind vane. See bellow for a list of tested models - Inspeed E-Vane 2 - Davis 6410 - Novalynx, model 200-WS-02F - Environmental Measurements Limited, model model WSD1 - DIDCOT, model DWD205 - Almost all 5V analogue wind vanes will work */ #define WDirSensor_Type  20  // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- //          Analogue Vane Offset Calibration // -------------------------------------------------------------------------------------- #define WDir_offs        0   // Usally there is no need to change default value (zero) // -------------------------------------------------------------------------------------- //   Define Rain Gauge tip boucket value (mm) // -------------------------------------------------------------------------------------- /*  Use 0.280 for standard FineOfset rain gauges (Datasheet value = 0.2794)  Use 0.200 for standard metric Davis rain gauges  Use 0.254 for standard imperial Davis rain gauges */   #define COLLECTOR_TYPE  0.200  // Please note: Values must be in metric units. Max. resolution: 3 decimal digits   // -------------------------------------------------------------------------------------- //   Define type of UV Sensor // -------------------------------------------------------------------------------------- #define UV_Sensor  0      // 0= UVM-30A, 1= VEML6075, 9= Not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Enable Disable // -------------------------------------------------------------------------------------- #define SoilLeaf_Interface     0   // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface #define Number_AnalogSensors   2   // Up to 4 analog sensors // -------------------------------------------------------------------------------------- //   Define which data this unit will send. 0 = Not send this data, 1= Send this data // -------------------------------------------------------------------------------------- #define ID0  1  // Temp/Hum Data #define ID1  0   // Not Used #define ID2  1   // Wind data #define ID3  1   // Rain data #define ID4  1   // SolRad / UV data #define ID5  1   // Hardware Status - System Temp, Battery Voltage etc #define ID7  0   // Send Soil & Leaf Temperature Data #define ID9  0   // Send Soil & Leaf Moisture / Wetness Data // -------------------------------------------------------------------------------------- //   Hardware settings // -------------------------------------------------------------------------------------- // SHT31 I2c Address // Default address will work most of the times! #define SHT31_address 0x44           // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Debug // -------------------------------------------------------------------------------------- #define Debug_Enable      false #define DebugID0          false #define DebugID2          false #define DebugID3          false #define DebugID4          false #define DebugID5          false #define Easyweather_Test  false #define Debug_SLinterface false // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
The cover material for the sensor is a piece of 1mm JGS1 glass and i have set the transmission percentage at 95% as a starting point.
Any help would be appreciated
RE: Help with UVM30A - werk_ag - 19-01-2018
Hi Jim,
Everything seems fine with the config files.
If your Solar/UV interface its an older v3.10 or v3.20 board, you need to swap the Vcc and Sig connections at the UVM30A connector on the board (Those boards had an error on the connector labels, everybody was warned about that before ordering the boards).
After checking the UVM30A connection you can enable the Debug options on the TX software, that will help you to see if the TX unit is reading anything fromthe sensor
// -------------------------------------------------------------------------------------- //   Debug // -------------------------------------------------------------------------------------- #define Debug_Enable      true #define DebugID0          false #define DebugID2          false #define DebugID3          false #define DebugID4          true #define DebugID5          false #define Easyweather_Test  false #define Debug_SLinterface false
On the Serial monitor you should have some values on "ADC1 - avg UV   : "
Since you are working on it, its a great time to upgrade all your units to v5.0 software.
RE: Help with UVM30A - Barrow4491 - 20-01-2018
(19-01-2018, 20:43)Werk_AG Wrote:  Hi Jim,
I had forgotten the swapped connections on the board and I will check it out when next on the roof.
i will load my spare Tx with v5 and change it after I have solved the UV issue
My board is v3.21 and the connections are marked correctly. (I will suspend the upgrade to v5 software until I resolve the UV issue)
As it is difficult to access the roof with my laptop I set up my spare Tx board and connected a UVM-30a only direct to the board and the following code was received on my front balcony in the early morning (0800 with an overcast sky)
DataPacket ID4: 161,4,1023,208,0,0 ACD0 - SolarRad :1023   SolarRad :1400 ADC1 - avg UV   : 208  Indice UV : 0.0 Sending... DataPacket ID4: 161,4,1023,189,0,0 ACD0 - SolarRad :1023   SolarRad :1400 ADC1 - avg UV   : 189  Indice UV : 0.0 Sending... DataPacket ID4: 161,4,1020,185,0,0 ACD0 - SolarRad :1020   SolarRad :1395 ADC1 - avg UV   : 185  Indice UV : 0.0 Sending... DataPacket ID4: 161,4,990,175,0,0 ACD0 - SolarRad :990   SolarRad :1354 ADC1 - avg UV   : 175  Indice UV : 0.0
I don't understand the readings but you no doubt will be able to analyse them
RE: Help with UVM30A - werk_ag - 21-01-2018
Hi Jim,
From what I see, I can say that you are getting readings from the UVM-30. The values correspond to the meteo conditions described.
Don't worry about seeing the Indice UV = 0, it isn't calculated on the Debug.
Indeed, the labels on Solar / UV 3.21 are correct.
RE: Help with UVM30A - Barrow4491 - 21-01-2018
(21-01-2018, 01:36)Werk_AG Wrote:  Hi Jim,
Don'k know what has happened but I ran the serial monitor on the Tx and all looked good and reloaded the final v4 software and suddenly the UV reading is on the Rx ???
Hate it when that happens
Will now attempt the V5 upgrade
