Software V5 - Onde colocar dados de acesso WU e WiFi? - Printable Version
+---- Forum: Suporte Geral em Português (https://www.meteocercal.info/forum/Forum-Suporte-Geral-em-Portugues)
+---- Thread: Software V5 - Onde colocar dados de acesso WU e WiFi? (/Thread-Software-V5-Onde-colocar-dados-de-acesso-WU-e-WiFi)
Software V5 - Onde colocar dados de acesso WU e WiFi? - CT7AEB - 06-01-2018
Hello!
In the RX Internet configuration where I put the weatherundeground ID and password and the wifi network?
//   Internet Settings
#define Enable_Internet     1                       // 1= Enable Internet connection, 0= Disable
// ---- NTP Settings ----
#define Enable_NTP          1                       // 1= Enable Sync time with NTP servers, 0= Disable
// NTP Servers:
#define timeServer "pool.ntp.org"
//#define timeServer "time.nist.gov"                 // ntp1.nl.net NTP server
//#define timeServer "80.96.196.58"                  // timp.mcsi.ro
//#define timeServer "193.79.237.14"                 // ntp1.nl.net NTP server
// ---- Weather Wunderground Settings ----
#define Enable_WUupload     1                        // 1= Enable upload to Wunderground, 0= Disable
#define WUupload_period     4                        // Period in minutes between uploads to WU (Should be >= 3 minutes, if less defaults to 4 minutes)
#define WUupload_InTemp     0                        // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
// ---- Air Quality Monitor - Upload to ThingSpeak Settings ----
#define Enable_AQMtoThingSpeak   0                   // 1= Enable, 0= Disable
// ---- Web Server Settings ----
#define Enable_WebServer          0                  // 1= Enable 0= Disable
#define WebServer_port           80                  // WebServer port (default 80)
//   Enable / Disable GPIO routines - General Purpose Input / Output ports
#define UseGPIO  0   // 0=Disable, 1= Enable
//   Define display order of data screens on the TFT
//   Use sequentially numbers from 1 to 4. Use 9 to prevent a particular data screen to be shown
#define ExtraSensors_Data 3
#define SoilLeaf_Data     4
#define AirQuality_Data   1
#define TXinfo_Data       2
Best regards
Nélio Simões
RE: Software V5 - werk_ag - 06-01-2018
Olá Nélio, boa noite.
Nas ultimas versões do software para o Pro2 PLUS, e para facilitar o envio dos ficheiros de configuração em caso de necessidade, as informações com dados pessoais sensíveis são agora colocados nem Credentials.h
Cumprimentos
RE: Software V5 - CT7AEB - 06-01-2018
(06-01-2018, 21:17)Werk_AG Wrote:  Olá Nélio, boa noite.
Nas ultimas versões do software para o Pro2 PLUS, e para facilitar o envio dos ficheiros de configuração em caso de necessidade, as informações com dados pessoais sensíveis são agora colocados em Credentials.h
Cumprimentos
Boa noite Werk,
Obrigado e bom fim de semana.
Nélio Simões
