WD will not Compile - Printable Version
+--- Thread: WD will not Compile (/thread-1073.html)
WD will not Compile - Kart41 - 05-04-2017
Hi, I have finished building all three of my boards. The TX and RX both work fine and talk to each other.
I can not get the WD code to compile. I am pretty new to Arduino, and not sure where to go from here.
Thanks for your help.
Here is the error I receive when trying to compile the sketch:
Quote:Arduino: 1.8.2 (Windows 10), Board: "Arduino Nano, ATmega328"
D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\WeatherDuino_Pro2_WD_v2.0_b008.ino: In function 'void setup()':
WeatherDuino_Pro2_WD_v2.0_b008:177: error: 'setSyncProvider' was not declared in this scope
     setSyncProvider(syncProvider);   // Sync system time with RTC
WeatherDuino_Pro2_WD_v2.0_b008:178: error: 'setSyncInterval' was not declared in this scope
     setSyncInterval(86400);          // Every 24 hours
D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\WeatherDuino_Pro2_WD_v2.0_b008.ino: In function 'void loop()':
WeatherDuino_Pro2_WD_v2.0_b008:256: error: 'minute' was not declared in this scope
   if (minute() != last_min1)
WeatherDuino_Pro2_WD_v2.0_b008:277: error: 'second' was not declared in this scope
     if ((BackLight_State == true) && (second() != last_second))    // Clock update interval - 1s
D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\D_TFT1.ino: In function 'void DisplayClock_TFT()':
D_TFT1:405: error: 'minute' was not declared in this scope
   if (last_min != minute())
D_TFT1:407: error: 'hour' was not declared in this scope
     sprintf(Clock_buf, "%02d:%02d", hour(), minute());
D_TFT1:412: error: 'day' was not declared in this scope
       sprintf(Clock_buf, "%02d-%02d-%d", day(), month(), year());
D_TFT1:412: error: 'month' was not declared in this scope
D_TFT1:412: error: 'year' was not declared in this scope
D_TFT1:414: error: 'year' was not declared in this scope
       sprintf(Clock_buf, "%d/%02d/%02d", year(), month(), day());
D_TFT1:414: error: 'month' was not declared in this scope
D_TFT1:414: error: 'day' was not declared in this scope
D_TFT1:422: error: 'second' was not declared in this scope
   if (second()%2)
D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\RX.ino: In function 'void ReceiveDataRF()':
RX:124: error: 'setTime' was not declared in this scope
     setTime(Hora, Minuto, 1, RX_Data[4], RX_Data[3], RX_Data[2] + 1900);
Multiple libraries were found for "LiquidCrystal_I2C.h"
 Used: C:\Users\scott\Documents\Arduino\libraries\LiquidCrystal-I2C
 Not used: C:\Users\scott\Documents\Arduino\libraries\LiquidCrystal
Multiple libraries were found for "Adafruit_HTU21DF.h"
 Used: C:\Users\scott\Documents\Arduino\libraries\Adafruit_HTU21DF
 Not used: C:\Users\scott\Documents\Arduino\libraries\Adafruit_HTU21DF_Library
exit status 1
RE: WD will not Compile - werk_ag - 06-04-2017
It seems that you have multiple copies of the same libraries installed. If insure about which libraries to delete, delete all copies of LiquidCrystal_I2C.h and Adafruit_HTU21DF, and install again the libraries included on the software package.
RE: WD will not Compile - Kart41 - 06-04-2017
(06-04-2017, 02:25)Werk_AG Wrote:  It seems that you have multiple copies of the same libraries installed. If insure about which libraries to delete, delete all copies of LiquidCrystal_I2C.h and Adafruit_HTU21DF, and install again the libraries included on the software package.
Thanks, that got rid of the multiple libraries, but the WD sketch still will not compile.
Same error as above. Both the TX and RX sketches work fine.
I also tried v2.0_b005  it gets the same error.
Here is the current error:
Arduino: 1.8.2 (Windows 10), Board: "Arduino Nano, ATmega328" D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\WeatherDuino_Pro2_WD_v2.0_b008.ino: In function 'void setup()': WeatherDuino_Pro2_WD_v2.0_b008:177: error: 'setSyncProvider' was not declared in this scope     setSyncProvider(syncProvider);   // Sync system time with RTC                                 ^ WeatherDuino_Pro2_WD_v2.0_b008:178: error: 'setSyncInterval' was not declared in this scope     setSyncInterval(86400);          // Every 24 hours                          ^ D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\WeatherDuino_Pro2_WD_v2.0_b008.ino: In function 'void loop()': WeatherDuino_Pro2_WD_v2.0_b008:256: error: 'minute' was not declared in this scope   if (minute() != last_min1)              ^ WeatherDuino_Pro2_WD_v2.0_b008:277: error: 'second' was not declared in this scope     if ((BackLight_State == true) && (second() != last_second))    // Clock update interval - 1s                                              ^ D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\D_TFT1.ino: In function 'void DisplayClock_TFT()': D_TFT1:405: error: 'minute' was not declared in this scope   if (last_min != minute())                          ^ D_TFT1:407: error: 'hour' was not declared in this scope     sprintf(Clock_buf, "%02d:%02d", hour(), minute());                                              ^ D_TFT1:412: error: 'day' was not declared in this scope       sprintf(Clock_buf, "%02d-%02d-%d", day(), month(), year());                                              ^ D_TFT1:412: error: 'month' was not declared in this scope       sprintf(Clock_buf, "%02d-%02d-%d", day(), month(), year());                                                       ^ D_TFT1:412: error: 'year' was not declared in this scope       sprintf(Clock_buf, "%02d-%02d-%d", day(), month(), year());                                                               ^ D_TFT1:414: error: 'year' was not declared in this scope       sprintf(Clock_buf, "%d/%02d/%02d", year(), month(), day());                                               ^ D_TFT1:414: error: 'month' was not declared in this scope       sprintf(Clock_buf, "%d/%02d/%02d", year(), month(), day());                                                        ^ D_TFT1:414: error: 'day' was not declared in this scope       sprintf(Clock_buf, "%d/%02d/%02d", year(), month(), day());                                                               ^ D_TFT1:422: error: 'second' was not declared in this scope   if (second()%2)              ^ D:\Arduino\WeatherDuinoPro2\Software\WeatherDuino_Pro2_Newest\software\WD software\WeatherDuino_Pro2_WD_v2.0_b008\RX.ino: In function 'void ReceiveDataRF()': RX:124: error: 'setTime' was not declared in this scope     setTime(Hora, Minuto, 1, RX_Data[4], RX_Data[3], RX_Data[2] + 1900);        ^ exit status 1 'setSyncProvider' was not declared in this scope This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Please check if you are using the RTClib included on the WeatherDuino Pro2 software package.
(06-04-2017, 05:01)Werk_AG Wrote:  Please check if you are using the RTClib included on the WeatherDuino Pro2 software package.
I am, to be sure I just deleted and reinstalled. Same errors
I have just finished installing Arduino IDE 1.8.2, and the software compile without errors.
For now I'm not seeing what can be causing the compilation error that is happening to you. If I get any idea which can help I will post it .
(06-04-2017, 06:07)Werk_AG Wrote:  I have just finished installing Arduino IDE 1.8.2, and the software compile without errors.
Thanks Werk_AG, this happened after I upgraded to IDE 1.8.2
I have compiled the WD sketch before and uploaded to my Nano, but after I upgraded the IDE it will not compile.
I will,try a different computer tonight with an earlier IDE version.
I re downloaded the software and the WD sketch compiles fine.
RE: WD will not Compile - hornychz - 06-04-2017
Congratulations!  Smile
