Some Newby Questions - Printable Version
+--- Thread: Some Newby Questions (/thread-1071.html)
Some Newby Questions - Speedy68 - 03-04-2017
Hello
My Weatherduino Pro 2 is running.
But i have some (newby) questions.
If the Software start i see some numeric Codes. First 000 and later 100 or 110 than it display Data from TX. What it means?
If i start the Software (program switch on) 000, 010, 011 than it display data from TX.
I use Cumulus with win10. What is the USB reading interval? I think 1 sec. ? I am not shure.
On my old mh1080 in Cumulus screen "New Record" is blinking if cumulus read data from Station. Now "New Record" do nothing, but Data was read. It is normal or not?
Regards.
RE: Some Newby Questions - Palmyweather - 03-04-2017
Hi Speedy68
The numeric codes that first show up before the data displays is a great little feature. It indicates that data is being sent from the transmitter to the receiver. It needs all three zeros (0) to turn to ones (1) before it shows any data. This makes sure the transmitter is working correctly and sending the temperature, wind and rain information. Depending when the receiver is turned on, it will show the numerical codes in different paterns, depending on where the transmitter is up to in sending data.
The "New Record" light should only blink if a new record has been made. For example, if the temperature goes higher than previously recorded by Cumulus, or you get a wind gust that exceeds previous readings. When starting out, the New Record light will flash a lot as new data comes theough that exceeds previous data. It will settle down into what will become "normal" for your environment and the New Record light should flash less.
Hope this helps,
PalmyWeather
RE: Some Newby Questions - Speedy68 - 05-04-2017
Hello
I have test some days.
I think i have a Problem with my PC for the weather station. It is a Cenovo mini PC. The "New Record" not flashing.
The Cenovo runs with Win10 32 bit. USB Rate set to 19200.
If i use my Laptop Win10  64 bit "New Record" is flashing.
But i dont know why the Cenovo do not. But FTP upload works. Only the Rapid Fire data for WU must have a Problem.
I have activate Rapid fire and the normal upload interval is 1 minute. But WU say the station send date between 6 or 15 minutes ago. https://www.wunderground.com/personal-weather-station/dashboard?ID=IHUNDESH4#history
The graphs are OK.
Need a idea.
Update:
Now i have found this site: https://www.wunderground.com/swf/Rapid_Fire.swf?units=metric&station=IHUNDESH4
And i can see rapid fire works. But not on the main page of the Station.
I send Soil Moisture, Soil Temp and Leaf Wetness data. Can this be the Problem of Main WU Page ?
RE: Some Newby Questions - hornychz - 05-04-2017
(05-04-2017, 12:37)Speedy68 Wrote:  Update:
Hi Spedy68,
I think they had a problem, but now it would be OK. Try it again ...  Smile
RE: Some Newby Questions - Speedy68 - 06-04-2017
Hello Zdenek
Now i also think that WU have a Server Problem. I have run Debug. WU anwers are all Ok.
