Nano soldering - Printable Version
+--- Thread: Nano soldering (/thread-103.html)
Nano soldering - water01 - 14-09-2014
Werk_AG or uncle_bob did you solder the Nano directly to the boards or did you put the chip in a holder so it can be changed if necessary?
About to start work on mine as I have nearly got all the bits!!
RE: Nano soldering - werk_ag - 14-09-2014
I have always soldered directly on the board, just do a small test before soldering to see if the Arduino Nano is working well. I do this because once, only after soldering I realized that the FTDI chip was defective.
Solder the nano in a socket may be a good idea.
A connector like the one on image below can be used as a socket for the Arduino Nano.
[Image: yhst-27389313707334_2252_86879937]
RE: Nano soldering - uncle_bob - 14-09-2014
I've done both techniques.
On my stripboard model, most things were socketed.
On my PCB version, I soldered directly.
RE: Nano soldering - water01 - 15-09-2014
Thanks both for your help.
