Clarifications on parts lists - errata? -
clubjoker - 27-02-2017
Hello
I'm just ordering components for a system build (2*TX, RX, RX+), and have a couple of questions on the parts lists.
RXv5.02
- Is the BMP280 barometric pressure sensor supported on the RXv5.02? (The parts lists only says BMP180 or BMP085, but I recall reading somewhere about support for it being added...).
- Is the SHT31 supported on the RXv5.02? (Parts lists says "DHT22 or HTU21D", but I thought I read about support for SHT31 being added to all the WeatherDuino family here
http://www.meteocercal.info/forum/Thread-Temperature-sensors-options - maybe the parts list hasn't been updated?)
TXv3.12
- What temperature/humidity sensors are supported? The parts list states TMP36 as optional IC2, which I understand to be for the PCB/system temperature. The parts lists doesn't mention specific temperature/humidity sensors. The PCB is marked "SHT2X/F(?)I2C, SHT1X/DHT22". Is the SHT31 also supported for the TX? (I read about support for SHT31 being added to all the WeatherDuino family)
Thanks very much
John
RE: Clarifications on parts lists - errata? -
Looking at "Config_TX.h", I see a configuration option for SHT31 mentioned. So that suggests that the SHT31 is now supported by the TX.
werk_ag - 27-02-2017
Looking at the software is always the best way to see which sensors are supported.
(27-02-2017, 12:37)clubjoker Wrote: RXv5.02
The BMP280 and BME280 are only supported by the WeatherDuino Pro2 PLUS. Systems based on RX v5.02 or v6.xx should use the BMP180 or BMP085
(27-02-2017, 12:37)clubjoker Wrote: - Is the SHT31 supported on the RXv5.02? (Parts lists says "DHT22 or HTU21D", but I thought I read about support for SHT31 being added to all the WeatherDuino family here http://www.meteocercal.info/forum/Thread-Temperature-sensors-options - maybe the parts list hasn't been updated?)
Currently the SHT31 is supported by all RX versions.
(27-02-2017, 12:37)clubjoker Wrote: TXv3.12
I think you already have found the answer.
Thanks, Werk. All clear now, and I can see in the config header files too
