(08-12-2019, 18:45)Werk_AG Wrote:(08-12-2019, 18:00)ok2arm Wrote: Hi,
I would like all importatnt info on main screen...
Now is +/- this:
ATM xx Inside
Wind xx XX
Wind xx XX
Wind xx Outside
Rain xx XX
Rain xx XX
Solar xx
UV xx
I would like make this on main page:
ATM xx Inside Temp xx
Wind xx Inside Pres xx
Wind xx Outside Temp xx
Wind xx Outside Pres xx
Rain xx PM10 xx
Rain xx PM2,5 xx
Solar xx AQ xx
UV xx CO2 xx
Is real to make ?
Tnx
Hi Joe,
Obviously it can be done, its a change you can try to do. Honestly, I don't want to do it, as it will also break coerency with the WiFi Wireless Display and probably will require changes on the structure of the language files (not apparently, but it will have). By other side, Air Quality data isn't part of the standard set od data provided by Davis Vantage weather stations, which WeatherDuino emulates, so having Air Quality data on a a separated data screen, seems to make sense.
