3D printed box for Air Quality Monitor II - Printable Version
+-- Forum: Weather Equipment - General Discussion (https://www.meteocercal.info/forum/Forum-Weather-Equipment-General-Discussion)
+--- Forum: Weather Equipment (https://www.meteocercal.info/forum/Forum-Weather-Equipment)
+--- Thread: 3D printed box for Air Quality Monitor II (/Thread-3D-printed-box-for-Air-Quality-Monitor-II)
Pages: 1 2 3 4 5 6
RE: Case for AQM II - jarekh3 - 24-01-2020
(24-01-2020, 11:19)hornychz Wrote:  Thank you, boys,
I will try to again...  Idea
If it fails, I will send you an STL file without subtitles.
Btw.. Slicer preview  (PrusaSlicer 2.1.0):
[Image: 42dc1ebf3237.png]
RE: Case for AQM II - hornychz - 24-01-2020
(24-01-2020, 12:52)jarekh3 Wrote:  If it fails, I will send you an STL file without subtitles.
Thank you, Jarek,
Today I learned something a bit and stopped using Cura, but installed Repetier-Host and PrusaSlicer...
It is completely in the Czech language and I think much more better for me.
(I assumed that Cura is the most widespread in the world, so it should be the best. But today I read an
article - probably from Prusa - that it is very complex and chaotic to operate. I struggled with it for 1 year.)
We will see -> now I'm trying another attempt...
Eureka! Printed without any problems. Things seem much easier with Czech software ...
[Image: IMG_20200124_182151-upr-sm.jpg]
Thank you for your help.
(24-01-2020, 18:32)hornychz Wrote:  Eureka! Printed without any problems. Things seem much easier with Czech software ...
Looks better  Like Big Grin
Quote:Today I learned something a bit and stopped using Cura, but installed .... PrusaSlicer
It's a good idea.
RE: Case for AQM II - AllanG - 24-01-2020
...for me, things always seem much easier with Czech beer!!  Big Grin
That looks very good, Zdenek. I too have been using Cura since I got my printer last year. I have had some good results using it, but I have also had a lot of failures. I installed Prusa Slicer a week ago and have started to learn how to use it, but I have not yet printed anything with it. I think I will try the front plate for the Pro2+ case again. I have a good one using Cura but have always thought the logo could be better. I will now try with Prusa and find out!
Allan.
RE: Case for AQM II - uncle_bob - 24-01-2020
Good stuff Zdenek Like Like
Like  Yes, Allan, you are right!
Ultimaker Cura is good, because you can slice and print too with it. When you use PrusaSlicer, it can't print, you have to use another software.
I installed the Repetier-Host v2.1.6 (not Repetier-Server -> it is enabled by default!) the first. It has PrusaSlicer inside, but old version,
so after this I has installed PrusaSlicer v2.2.0-alpha2. And at the end is needed to configure Repetier-Host "directory with config files of Creality Ender-3",
in my case they are in C:\Users\hornychz\AppData\Roaming\PrusaSlicer-alpha (it is a hidden directory).
I must say that PrusaSlicer has much more better preview then Cura and Repetier-Host can display printing process, Cura doesn't it...
RE: Case for AQM II - werk_ag - 25-01-2020
Seems I will not have a 3D printer so soon Sad . Too many things to learn ReadManual , and WeatherDuino already takes up all the free time I have.
RE: Case for AQM II - werk_ag - 26-01-2020
Contrarily to what I said on previous post, I decided to join the club... Finally I bought a 3D printer!
From my side, its possible that WeatherDuino development will slow down a bit on the upcoming times. I always liked to do one thing at the time, and give all attention to what I'm doing at the momment. Now its time to learn about 3D printing... ReadManual Angry ReadManual Angry ReadManual Undecided ReadManual Smile (hopefully)
RE: Case for AQM II - uncle_bob - 26-01-2020
Great! What model did you buy?
