Data logging addon - Printable Version
+--- Forum: Third-party Addons (
https://www.meteocercal.info/forum/forum-51.html)
+--- Thread: Data logging addon (
/thread-1434.html)
RE: Data logging addon -
engolling - 15-02-2020
Hi Laurent,
attached you can find an updated version which should fix the mail issue. I will update also the version on git soon.
laulau - 19-02-2020
(15-02-2020, 23:25)engolling Wrote: Hi Laurent,
Sorry for the late response, it works now
Just a little thing: when no data incoming mail is sent but in console "Mail is already sent." message is repeted until the datas are present again.
engolling - 19-02-2020
I will fix this with the next release on git hub. I'm also planning a function to send a mail when the mail TX unit is down. I had this due to a faulty PSU and ATM you get straigt lines.
Maybe I also write an algoritjm which is able to detect automatically straigt lines within some specified amount of time.
... noted in my internal to-do list
laulau - 19-02-2020
AQM_Temp and AQM_Hum factor should be 100 not 10 in Signal_Description.
Quote:AQM_PM1_0: 2.6 µg/m³
AQM_PM2_5: 3.7 µg/m³
AQM_PM10_0: 4.4 µg/m³
AQM_Index: 18.0
AQM_Temp: 64.3 °C
AQM_Hum: 577.8 % r.H.
GAS_1: 1032.0 ppm
GAS_2: 1013.0 ppm
engolling - 04-03-2020
I was able to check this and it should work with 10 if you modify the software as described on the install guide on page 8.
By the way - I updated the source at github with the latest version.
engolling - 02-01-2021
Updated the files at Github to support the Pro2Plus Software v9.
