TX board help - Printable Version
+--- Thread: TX board help (/thread-1141.html)
Pages: 1 2 3 4
RE: TX board help - danner - 08-06-2017
Receive box mostly finished. Need to make a WeatherDuino Pro2+ sticker for it to add a little color to an otherwise drab box.
[Image: 0hZJ5D1.jpg]
RE: TX board help - hornychz - 08-06-2017
Very nice job, Danner!
Congratultions!  Smile
RE: TX board help - danner - 09-06-2017
Thanks!
My new crimp pliers just showed up today so I'll be redoing the connectors and wires. Things are so much easier when you have the correct tools. :-)
RE: TX board help - laulau - 09-06-2017
(07-06-2017, 07:27)danner Wrote:  I am very impressed with the range. TX1 was in my garage on the other side of the house. The signal went through at least 8 walls across roughly 90 feet so I don't foresee any communication issues. It will be interesting though to see whether I get interference on 432MHz or vice versa. But I will cross that bridge when I get to it.
Which type of antenna are you using ?
I got it from ebay doing a search for 16cm 433MHz antenna from this list. http://www.meteocercal.info/forum/thread-216-post-3684.html#pid3684
The ebay link to the item I purchased is here.
I was going to make my own, but I'm done with making things for a while, LOL.
RE: TX board help - zitoune - 12-06-2017
Well done !
RE: TX board help - danner - 12-06-2017
Thanks.
I recently wired my SHT31 to a 6ft/2m long CAT5E and so far so good. I will be wrapping the excess cable around a #31 ferrite toroid to hopefully choke off any RF that may decide to use the CAT5 as an antenna. My back yard has very strong RF fields so I am concerned about it. It will be interesting to see how everything reacts to the RF once I get it all installed.
