WeatherDuino Pro2 Wireless Display - What is it? - Printable Version
+--- Thread: WeatherDuino Pro2 Wireless Display - What is it? (/thread-183.html)
RE: WeatherDuino Pro2 Wireless Display - What is it? - Ardummy - 28-03-2016
(28-03-2016, 00:03)Werk_AG Wrote:  Ardummy, the problem described before should be related to anything else. Changing that value, to anything above 59 (and below 255), should give the same result. Anyway I will try do discover why it works for you.
Thank you
Hola Werk_AG he comprobado que todo funciona bien y las lecturas son correctas te coloco una foto con las lecturas de Tx info.
Muchas Gracias por tu gran ayuda si necesitas que haga alguna prueba ... sin problema.
[Image: attachment.php?aid=610]
RE: WeatherDuino Pro2 Wireless Display - What is it? - Barrow4491 - 22-07-2016
(25-03-2016, 16:44)zitoune Wrote:  Thanks Werk for the great job ! The new WD screen looks awesome !
Here you go with the pict!
Hi
I am waiting for my boards ti arrive but am getting parts together. Could you let me know where you obtained the case
RE: WeatherDuino Pro2 Wireless Display - What is it? - zitoune - 22-07-2016
Hi
Hello Jim, and welcome here!
i got mine here
Good luck!
Zitoune
RE: WeatherDuino Pro2 Wireless Display - What is it? - zitoune - 20-08-2016
Hi Jim, have you finally gotten such enclosure or build your WD?
Thanks.
RE: WeatherDuino Pro2 Wireless Display - What is it? - JT118 - 20-08-2016
Ebay.co.uk searches for enclosures. Bit expensive for what they are. In the description he says leave a note if you do not want the UNO cutouts done, perhaps we can ask him to do a special "Weatherduino Pro2" cutout!
Adafruit PiTFT 2.8" LCD TFT case enclosure for Arduino Uno/Mega
http://www.ebay.co.uk/itm/Adafruit-PiTFT-2-8-LCD-TFT-case-enclosure-for-Arduino-Uno-Mega-/122056501620?var=&hash=item1c6b226974:m:mL5wgOT6l0bzw0omqQX1hBQ
16x2 LCD enclosure / project case for Arduino UNO / Mega
http://www.ebay.co.uk/itm/16x2-LCD-enclosure-project-case-for-Arduino-UNO-Mega-/122056501246?var=&hash=item1c6b2267fe:m:mFUGjGyyk3o-kx1YDJItiUA
Go to his shop for other variations. (with buttons etc.)
http://www.ebay.co.uk/sch/hobby_parts_and_supplies/m.html?_nkw=&_armrs=1&_ipg=&_from=
RE: WeatherDuino Pro2 Wireless Display - What is it? - Barrow4491 - 20-08-2016
Hi
i got mine here
Good luck!
Zitoune
sorry to be late in my reply, I have been away for a while. I did order the case from the USA recently as they are not stocked in Australia but it has not arrived as yet.
I have started to construct my system and will post photos in the next few weeks
RE: WeatherDuino Pro2 Wireless Display - What is it? - fredthemufin - 01-11-2016
Jim, you can get these cases at Core Electronics
http://core-electronics.com.au/pitft-enclosure-for-raspberry-pi-model-b.html
RE: WeatherDuino Pro2 Wireless Display - What is it? - Barrow4491 - 01-11-2016
Thanks, that is a good price. Mine arrived from the US and I have been busy trying different construction methods to get it all into the limited space. I am overseas at the moment but will post the final result in late November when I return
(01-11-2016, 07:50)Barrow4491 Wrote:  Thanks, that is a good price. Mine arrived from the US and I have been busy trying different construction methods to get it all into the limited space. I am overseas at the moment but will post the final result in late November when I return
I look forward to seeing it.
Peter.
