RE: 4-days forecast problem -
hornychz - 14-05-2019
(14-05-2019, 12:35)Werk_AG Wrote: I believe I found the problem, hopefully I will solve it up to next weekend. I may need some help from Jarek and Zdenek to tell me the exact range of extended chars used on Polish an Czech. I will send a PM to both about this matter.
engolling: The problem is more prone to happen with the Pro2 PLUS than with the WD units.
OK. I am ready.
jarekh3 - 14-05-2019
I'm ready too
werk_ag - 14-05-2019
Thank you both.
Please just wait one or two days, currently I'm very busy with my job.
hornychz - 15-05-2019
(14-05-2019, 22:06)Werk_AG Wrote: Thank you both.
That was three hours, not two days!
werk_ag - 19-05-2019
Jarek and Zdenek
When possible please try latest software, released today.
Please note:
This version includes a fork of the original DarkSkyWeather library, which was been optimized for the WeatherDuino system.
On the new software version, two minutes after you go to the 4 Days Forecast view, system automatically returns to Main view.
Before compiling:
- Install the new WD_DarkSkyWeather library
- Update the JSON_Decoder-master library
- Update the TFT_eSPI library (included version is compatible with all WeatherDuino software and other software, so you can safely replace any installed version).
- Update the RadioHead library (included version is compatible with all WeatherDuino software and other software, so you can safely replace any installed version).
- VERY IMPORTANT - Upload the fonts and icons to SPIFFS memory by using the “ESP8266 Sketch Data Upload” menu option in the Arduino IDE.
Waiting for your feedback.
hornychz - 19-05-2019
(19-05-2019, 01:30)Werk_AG Wrote: Jarek and Zdenek
Please note:
Before compiling:
All is looking fine, but "ě" and "Ě"... These letters are not viewable.
The bad texts are:
"4 DENNÍ PŘEDPOV
ĚĎ"
"B
ěhem dne převážn
ě zataženo"
jarekh3 - 19-05-2019
Everything works perfectly now. Thanks Armindo
I have only two comments:
The text "Please wait, getting data" is untranslated (this is not a big problem).
The third dot is yellow (bigger problem).
J.
aaa... the letter "Ł" does not work on the "System Info" screen (WYŁ/WŁ - off/on).
That was from the version v3.0_b007
(19-05-2019, 16:01)hornychz Wrote: The bad texts are:
"4 DENNÍ PŘEDPOVĚĎ"
"Během dne převážně zataženo"
Fixed.
Just update the SPIFFS files.
Thanks.
(19-05-2019, 16:05)jarekh3 Wrote: Everything works perfectly now. Thanks Armindo
J.
Thanks.
The untranslated text "Please wait, getting data" shown before each 4 Days Forecast update isn't a bug... That is something that have come to stay.
(19-05-2019, 16:05)jarekh3 Wrote: The third dot is yellow (bigger problem).
Only the third dot? All text sentence should be in yellow colour.
Sometimes this small details have a big importance. Do you have a picture?
(19-05-2019, 16:05)jarekh3 Wrote: aaa... the letter "Ł" does not work on the "System Info" screen (WYŁ/WŁ - off/on).
The letter "Ł" is included on the font. It should be shown.
Have you checked with latest release Pro2 Compact v3.0_b011?
