RE: Online Stations Map -
werk_ag - 10-01-2019
(10-01-2019, 02:39)41south Wrote: Something is a little awry (yes the co-ordinates are correct, I double checked)
and the url I set does not seem to show
Welcome to Picton Weather!
Last time that both of your weather stations have successfully contacted the WeatherDuino Server, none of them sent any URL.
[2019-01-08 11:31:17 Lisbon time] Device Type: P2ESP8266RX
[2019-01-01 01:04:31 Lisbon time] Device Type: P2AT2560RX
41south - 10-01-2019
Strange, it's definitely in there. I'm about to do the update so will see after that
Edit: Whoops, there's no update for the Pro2 compact so I won't do that
const char* WeatherStation_Name = "41south"; // Put here your Weather Station name or Location name - DON'T LEAVE EMPTY
const char* WeatherStation_URL = "http://41south.net.nz"; // If you have an URL to your Meteo Website put it here (can be the WU URL). URL should start with http or https
Can you confirm that the lat/lon should be 3 decimal places or 5? I see mine is a little out so I will update it
- Precision of the Latitude and Longitude data has enhanced from 3 to 5 decimal places (thanks
t3gathome for your research on this).
but in the code it says
// Put here your Station latitude in degrees North (always use 3 decimal places)
And this station [[2019-01-01 01:04:31 Lisbon time] Device Type: P2AT2560RX] is now replaced so can be removed (or will it just remove itself over time?
(10-01-2019, 04:36)41south Wrote: Can you confirm that the lat/lon should be 3 decimal places or 5? I see mine is a little out so I will update it
- Precision of the Latitude and Longitude data has enhanced from 3 to 5 decimal places (thanks t3gathome for your research on this).
On Config_Options.h of latest Pro2 PLUS release v8.1_b002, I can see this:
// Define your Weather Station location. Use decimal format for Latitude and Longitude
#define LATITUDE 39.22350 // Put here your Station latitude in degrees North (with up to 5 decimal places, don't use less than 3 decimal places)
#define LONGITUDE -8.99650 // Put here your Station longitude in degrees - minus for West (with up to 5 decimal places, don't use less than 3 decimal places)
#define ELEVATION 124 // Put here your Station height above sea level in Meters (no decimal places)
On Config_Options.h of latest Pro2 Compact release RX v2.1_b001, I can see this too:
#define LATITUDE 39.22350 // Put here your Station latitude in degrees North (up to 5 decimal places, don't use less than 3 decimal places)
#define LONGITUDE -8.99650 // Put here your Station longitude in degrees - minus for West (up to 5 decimal places, don't use less than 3 decimal places)
(10-01-2019, 04:36)41south Wrote: And this station [[2019-01-01 01:04:31 Lisbon time] Device Type: P2AT2560RX] is now replaced so can be removed (or will it just remove itself over time?
it will just remove itself over time.
Excellent, sorted, thanks.
Did you see anything I need to change in my url for it to show? Or is it possibly because there are 2 stations showing?
It is listed now.
No problem with having two or more weather station on the same location. Each one can have the same or a different name and URL.
Indeed as we can see on the map, there are some users with two WeatherDuino weather stations on the same location.
werk_ag - 14-01-2019
Welcome DLangWeather!
The first WeatherDuino weather station in Canada to be listed on the map
I believe that another one, also in Canada, will be added soon.
