Data logging addon - Printable Version
+--- Forum: Third-party Addons (https://www.meteocercal.info/forum/forum-51.html)
+--- Thread: Data logging addon (/thread-1434.html)
Pages: 1 2 3 4
RE: Data logging addon - engolling - 15-07-2019
Updated files on GitHub
Changelog:
- Changes in handling of the unit type to have full compatibility with the WeeWx plugin
RE: Data logging addon - engolling - 17-09-2019
Updated files on GitHub.
Changelog:
Added data validation for TX sensor data from "additional" TX modules which are not configured as main sensor to remove "0" values coming when the packages are not received at the RX already.
RE: Data logging addon - laulau - 08-02-2020
I'm running the script under Window with Python2.7 successfully except sending mail.
is there something to adapt in sendmail because although I modify the parameters the sending is not done.
Quote:2020-02-08 10:56:58 Logging script started.
08.02.2020 10:58:59 Mail could not be sent.
RE: Data logging addon - engolling - 08-02-2020
Line 430 - 443:
                                                try:       # call sendmail() and generate a new mail with specified subject and content                                                         if EnableDebug == 1:        print "Sending Email."                                                         sendmail(str(receiver),'Wetterstation error',str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) + ' No data is logged since 10 minutes')                                                         if EnableErrorLog == 1:        with open(ErrorLog,'a') as err:        err.write (str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) +" Mail sent to " + str(receiver) + "\n")        mailSent = 1                                                 except:                                                         if EnableErrorLog == 1:        with open(ErrorLog,'a') as err:        err.write (str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) +" Mail could not be sent. \n")        mailSent = 1
You change it like this:
                                               # try:       # call sendmail() and generate a new mail with specified subject and content                                                         if EnableDebug == 1:        print "Sending Email."                                                         sendmail(str(receiver),'Wetterstation error',str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) + ' No data is logged since 10 minutes')                                                         if EnableErrorLog == 1:        with open(ErrorLog,'a') as err:        err.write (str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) +" Mail sent to " + str(receiver) + "\n")        mailSent = 1                                                 #except:                                                         #if EnableErrorLog == 1:        #with open(ErrorLog,'a') as err:        #err.write (str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) +" Mail could not be sent. \n")        #mailSent = 1
Comment the "try" and the whole "except" section then the script will crash with the "real" error message. Otherwise it is always hidden behind de exception.
I tryed but the script doesn't crash !
(I unplug RX for the email test)
Quote: .......
Rain_TX3: 0.0 mm
Rain_Rate_TX3: 0.0 mm/h
Actual timestamp:2020-02-08 22:54:48; Timestamp at sending:2020-02-08 22:54:53
Sending Email.
An error has happened during receiving. Waiting 5 minutes and start over again
2020-02-08 23:00:49 Open serial interface COM14
2020-02-08 23:00:49 Successfully opened.
Sending Email.
In error log :
Quote:2020-02-08 22:55:48 Error receiving data from serial port. Maybe connection was lost. Error code:15
2020-02-08 23:00:49 Error receiving data from serial port. Maybe connection was lost. Error code:15
RE: Data logging addon - engolling - 09-02-2020
So for the script itself everything seems to be fine. But you do not get an e-mail.
You checked the server stuff twice?
Moreover you most of the time have to setup your router to allow sending.
RE: Data logging addon - laulau - 09-02-2020
I know it's a bit off topic because it's not a Python forum, but it can be simple for you to answer me
I made another script for sending mail and I have this as an error message:
Quote:  sendmail(str(receiver),'Wetterstation error',str(datetime.now().strftime("%d.%m.%Y %H:%M:%S")) + ' TEST')
File "Z:\Partage\Projets\Arduino\WD\Ori\WeatherDuino_Addon\sendmail.py", line 7, in sendmail
msg = MIMEText(content)
NameError: global name 'MIMEText' is not defined
It seems that sendmail.py script don't know the variables defined in the main script.
I managed to have an email from script by changing the sensmail script :
  # # function to send a mail # def sendmail(recipient,subject,content):   from email.mime.text import MIMEText   import smtplib   # generate a RFC 2822 message   sender = 'Sender@mail.com'   smtpserver = 'smtp.free.fr'   msg = MIMEText(content)   msg['From'] = sender   msg['To'] = recipient   msg['Subject'] = subject   # open SMTP connection   server = smtplib.SMTP(smtpserver)   # start TLS encryption   #if usetls:     #server.starttls()   # login with specified account   #if smtpusername and smtppassword:     #server.login(smtpusername,smtppassword)   # send generated message   server.sendmail(sender,recipient,msg.as_string())   # close SMTP connection   server.quit()
No sure it is a good solution Blush
Hi laurent,
I have to check this again. Probably I lost compatibility because I did not try this feature after releasing the last versions. Because I had no test system anymore.
I will check this annd release a fix if necesary. I think as long as your solution works it is fine .
Sorry for the inconvenience Blush
RE: Data logging addon - engolling - 14-02-2020
Hi laurent,
I confirm - at some stage I outsourced this function into an extra file and not there are some variables unknown.
You can leave your solution as it is.
There will be an update in the next days.
