RE: Wifi module -
qldbureau - 18-05-2018
(12-05-2018, 22:47)spudstrawb Wrote: I suspect that there might be an issue with Wunderground at the moment. Our power was off for several hours on Friday and I didn't receive any emails from Wunderground telling me that they'd stopped receiving data from my weather station (or started receiving it again) like I normally do when the power drops off.
I would not worry about this. I used to receive those messages after about an hour being off, and congratulated when back on. Never receive them anymore since several months ago. The gold star never appears anymore on mine either, yet the neighbour's never disappears.
RE: Wifi module -
markkkk42 - 18-05-2018
No mine hasnt been showing up on WU for like 3 months...When it was up at my farm it was doing this and its still doing it here at home..different connections. The wifi message is all ok. I will post it when I fire up my other mac I use for arduino stuff.
RE: Wifi module -
uncle_bob - 18-05-2018
I like to think my gold star is because I've got great data these days.
My wifi has been feeding WU faultlessly since I replaced my ESP.
https://www.wunderground.com/personal-weather-station/dashboard?ID=IACTCOND4#history/s20180511/e20180519/mweek
RE: Wifi module -
a bit chilly already in the town of the pollies who cant lay straight in bed
My wifi logs onto the router fine. I can see it and the debug says it fires up ok but WU doesnt see it...was that the same issue?..I watched your video..I love that new display too
RE: Wifi module -
Bob what instruments do you have attached?..also that wind is all over the place there...maybe lots of structures or big hills close by?
RE: Wifi module -
(18-05-2018, 09:20)uncle_bob Wrote: I like to think my gold star is because I've got great data these days.
I dont
think I am having issues with my WiFi module, at least I have not considered it. The green dots are always on at least. I did need to replace the temperature and humidity sensor again as the humidity went bust once more, but that was ages ago. I contemplated perhaps the air quality data is too much for them at the moment. The other thing is the NBN we are now on, but the neighbouring one should be on it unless they have not cut over yet. On the whole we have been o.k, though the last two weeks the evenings have been infuriating. Could not even pay a bill the other night.
Edit: I see you send AQI to Wunderground too, so cannot be it.
RE: Wifi module -
The 3 led on the display on the top left on mine since it does not go to WU has been top and bottom are green but the middle one is red
What does this mean I havent seen anything on them. There just used to be 2 led both were always green on the previous firmware
RE: Wifi module -
Yeah, if you can see the webserver on the RX unit then it does sound like your wifi is working OK.
My wind gets disturbed by the roofline of my house. On the old anemometer, I used to have a wheel on it just to add a little resistance and it helped stopping it flap all over the place. Alas I couldn't fit that mod to my new one.
I just have the standard stuff connected,
earth, wind and fire, I mean rain wind and solar.
RE: Wifi module -
Oh, did you try the WU API key instead of the user/password combo?
RE: Wifi module -
Hi Bob
I am not running CumulusMX....although I have just got a Pi 3 going with it running and it should connect to WU as I put the id in there but maybe because I dont have any sensors via the arduino connected yet. The ini file has my station ID and the key I use not my login password...its the same in the arduino but it still doesnt seem to work
