Davis Pro2 Digital Temperature Humidity Sensor (Sensiron SHT31) - Printable Version
+--- Thread: Davis Pro2 Digital Temperature Humidity Sensor (Sensiron SHT31) (/thread-1115.html)
RE: Davis Pro2 Digital Temperature Humidity Sensor (Sensiron SHT31) - werk_ag - 04-12-2017
(04-12-2017, 01:01)JT118 Wrote:  ... It appears V5 RX boards do not like SHT31 sensors. (I used the latest Pro software, and yes I did plug the sensor into the correct input on the RX board).
Hi JT118,
Tank you for this report. I will try to investigate this matter. In the meantime, do you have a link to the SHT31 sensor?
RE: Davis Pro2 Digital Temperature Humidity Sensor (Sensiron SHT31) - JT118 - 04-12-2017
It is this one, fairly standard issue Chinese clone.
https://www.ebay.co.uk/itm/1PCS-SHT31-SHT31-D-Temperature-Humidity-Sensor-Breakout-Weather-For-Arduino-CK/191890795555?
which works on the Rev 6 board and the ProPlus boards.
RE: Davis Pro2 Digital Temperature Humidity Sensor (Sensiron SHT31) - werk_ag - 05-12-2017
(04-12-2017, 20:11)JT118 Wrote:  It is this one, fairly standard issue Chinese clone.
Hi Jim,
Rev 5 and Rev 6 run the same software, so, we can discard a software issue. What seems probable to me, its something related with the I2C bus and its pullup resistors.
Since you say that the sensor works well with a Pro2 Rev 6 board, can you please verify this:
There are any resistors installed at R4 and R5 in your Rev 6 board?
If the Rev 6 is working without those resistors, then perhaps removing R5 and R6 on the Rev 5.xx board will solve the issue with those SHT31.
