New UK/Spain build, lessons, observations and questions along the way - Printable Version
+--- Forum: General Talking (
+--- Thread: New UK/Spain build, lessons, observations and questions along the way (
/thread-1092.html)
RE: New UK/Spain build, lessons, observations and questions along the way -
uncle_bob - 07-06-2017
(07-06-2017, 16:14)clubjoker Wrote: But I would like to find and fix the root cause of the apparently excessive power draw. I wonder if there is some static electricity damage.
While it's possible, I think it's more likely a resistor or capacitor could be in the wrong place.
clubjoker - 07-06-2017
(07-06-2017, 21:37)uncle_bob Wrote: (07-06-2017, 16:14)clubjoker Wrote: But I would like to find and fix the root cause of the apparently excessive power draw. I wonder if there is some static electricity damage.
Hmm. I think I've only added one capacitor to the board (a 100uF electrolytic, for the output of the 3.3V regulator). The rest of the passive components were already soldered surface-mounted SMD things on the board as supplied by Werk.
I've noticed, using a magnifying glass, that the values of the SMD resistors don't match the values on the schematic. They're the same order of magnitude though, so I thought it should be ok.
