Pro2 PLUS - Timezone config query - Printable Version
+--- Thread: Pro2 PLUS - Timezone config query (/thread-960.html)
RE: Pro2 PLUS - Timezone config query - Barrow4491 - 13-12-2016
It has now booted and I like the new look and it tells me that the RF efficiency is 80%.
I am now trying to connect to Cumulus MX, could you please advise how that is achieved
RE: Pro2 PLUS - Timezone config query - werk_ag - 14-12-2016
Hi Jim,
Are you joking? You should know the answer.
The Pro2 PLUS works exactly the same way than the Pro2.
Pro2 PLUS screen display - Barrow4491 - 14-12-2016
To allow me to understand the system better and save me putting annoying questions on the forum could you explain the
following features;
(a)  the two colored dots to the left of the time display
(b)  the com led
The reason I ask is that the new Rx was operating perfectly but now has the dots both red and no data is going to the WD's or W underground. I have rebooted to no avail. I assumed it was receiving data from the Tx as it got "W" "D" and then went to the weather screen, but no green lights
I reverted to the original Rx and all is good, so the Tx would appear to be OK
RE: Pro2 PLUS screen display - werk_ag - 15-12-2016
(14-12-2016, 08:43)Barrow4491 Wrote:  (a)  the two colored dots to the left of the time display
Hi Jim,
This is a good question, because until now I did not have the opportunity to talk about this on the forum. Considering the relevance of the question, I create a new thread about this matter. Please refer to it here:
http://www.meteocercal.info/forum/Thread-Pro2-PLUS-The-meaning-two-colored-dots-to-the-left-of-the-time-display
Quote:(b)  the com led
On the Pro2 PLUS, the COM_LED have exactly the same function than in all previous Pro2 receiver units, already described in several topics on the forum, however I will describe its function again.
At startup the COM_LED remains ON, until the system receives data from the outside sensors (Temperature / Humidity, Wind, and Rain), also giving you a visual signal to not attempt to start the weather software yet (Cumulus or any other).
After system initialization, the COM_LED goes off, and you could start your favourite weather software, then the COM_LED will blink every time the your weather software requests a data packet (more or less at each second) to the WeatherDuino receiver.
