2.8" tft displays - Printable Version
+--- Thread: 2.8" tft displays (
/thread-224.html)
RE: 2.8" tft displays -
werk_ag - 16-05-2015
(15-05-2015, 22:42)Brett Wrote: The Bon.Display version on ebay does not have a touch panel or controller attached...
It's always good to know some other sources for the displays, but I bought mine from Bon.Display and it have touch panel.
http://www.ebay.com/itm/2-8-240x320-Serial-SPI-TFT-LCD-Screen-Touch-Screen-Panel-PCB-Board-IC-ILI9341-/121544571128?pt=LH_DefaultDomain_0&hash=item1c4c9ef8f8
Brett - 19-05-2015
And so it is. Wow, I never thought eBay would be so hard to find LCDs ! AU's ebay searching won't show 2.8" displays, and bon.display's store didn't seem to have touch devices when I ordered. Always good to have options - who doesn't need another display or three
Paul_V - 20-05-2015
hi guys
I found another source, I bought my LCds here
http://www.ebay.com/itm/191531963190
strada916 - 24-05-2015
Hoping this is compatible?
http://www.aliexpress.com/item/3-2-TFT-LCD-Module-Display-Touch-Screen-Panel-PCB-Adapter-Blue-SSD1289-with-SD-Card/1443680146.html
or
http://www.aliexpress.com/item/3-5-TFT-LCD-Shield-Touch-Screen-Kit-Display-Case-Heatsinks-for-Raspberry-Pi/32325005734.html
Stuarts - 24-05-2015
I'm pretty sure that the first one isn't as it uses a 16 bit parallel interface rather than a SPI interface. The second one may work but you would have to work out which pins on a Raspberry Pi are used.
(24-05-2015, 12:08)Stuarts Wrote: I'm pretty sure that the first one isn't as it uses a 16 bit parallel interface rather than a SPI interface. The second one may work but you would have to work out which pins on a Raspberry Pi are used.
If you scroll down to interface it has pin-outs
Brett - 25-05-2015
It might be compatible, but it also might not be. The SPI interface could be significantly different to the one on all the smaller/previous displays. But if you wanted to give it a try, and report back, that'd be awesome
strada916 - 25-05-2015
(25-05-2015, 12:11)Brett Wrote: It might be compatible, but it also might not be. The SPI interface could be significantly different to the one on all the smaller/previous displays. But if you wanted to give it a try, and report back, that'd be awesome
I ended up going with 2.8" as per OP.
werk_ag - 25-05-2015
(24-05-2015, 12:04)strada916 Wrote: Hoping this is compatible?
or
None of them is compatible.
The second one, despite it is SPI, the seller don't even say any info about the chipset driver.
JT118 - 31-05-2015
3.2" TFT; will this work?
http://www.ebay.co.uk/itm/400916125089
