Home Assistant - Printable Version
+--- Forum: General Talking (https://www.meteocercal.info/forum/forum-68.html)
+--- Thread: Home Assistant (/thread-2227.html)
RE: Home Assistant - uncle_bob - 10-01-2024
Thanks Werk.
No problem.
As a side note, I'm using Json to get AQM II data into PRTG.
Hope you're New Year is off to a nice start.
Cheers,
UB
RE: Home Assistant - hornychz - 07-06-2024
(07-01-2024, 10:21)uncle_bob Wrote:  Here's the data I'm using so far.
[Image: Screenshot%202024-01-07%20200729.png]
Since the image is not visible, I decided to supplement this solution with an even more detailed guide:
1) definition in CumulusMX software
2) definitions, for example, in the file /homeassistant/mqtt.yaml (here it is in Czech language)
# MQTT - CumulusMX sensor: - name: "Teplota vzduchu" state_topic: "CumulusMX/Interval" suggested_display_precision: 1 unit_of_measurement: "°C" value_template: "{{ value_json.temp }}" - name: "Vlhkost" state_topic: "CumulusMX/Interval" suggested_display_precision: 1 unit_of_measurement: "%RH" value_template: "{{ value_json.humidity }}" - name: "Rychlost větru" state_topic: "CumulusMX/DataUpdate" suggested_display_precision: 1 unit_of_measurement: "m/s" value_template: "{{ value_json.windspeed }}" - name: "Směr větru" state_topic: "CumulusMX/DataUpdate" unit_of_measurement: "°" value_template: "{{ value_json.winddir }}" - name: "Nárazy" state_topic: "CumulusMX/Interval" suggested_display_precision: 1 unit_of_measurement: "m/s" value_template: "{{ value_json.wgust }}" - name: "Sluneční radiace" state_topic: "CumulusMX/Interval" unit_of_measurement: "W/m2" value_template: "{{ value_json.SolarRad }}" - name: "UVI" state_topic: "CumulusMX/Interval" suggested_display_precision: 1 unit_of_measurement: "" value_template: "{{ value_json.UVI }}" - name: "Srážky" state_topic: "CumulusMX/Interval" unit_of_measurement: "mm" suggested_display_precision: 1 value_template: "{{ value_json.rfall }}" - name: "Intenzita srážek" state_topic: "CumulusMX/Interval" unit_of_measurement: "mm/h" value_template: "{{ value_json.rrate }}"
3) result "text"
and definition of Entity card
type: entities entities: - entity: sensor.teplota_vzduchu icon: mdi:thermometer secondary_info: last-updated - entity: sensor.vlhkost secondary_info: last-updated icon: mdi:water-percent - entity: sensor.rychlost_vetru secondary_info: last-updated icon: mdi:weather-windy - entity: sensor.smer_vetru secondary_info: last-updated icon: mdi:directions-fork - entity: sensor.narazy secondary_info: last-updated icon: mdi:windsock - entity: sensor.uvi secondary_info: last-updated icon: mdi:sun-wireless - entity: sensor.slunecni_radiace secondary_info: last-updated icon: mdi:sun-angle - entity: sensor.srazky secondary_info: last-updated icon: mdi:weather-rainy - entity: sensor.intenzita_srazek secondary_info: last-updated icon: mdi:weather-rainy theme: Animated Weather Card state_color: true title: Údaje meteo stanice show_header_toggle: false
4) example of graphic processing
and its definition
type: history-graph entities: - entity: sensor.teplota_vzduchu - entity: sensor.uvi - entity: sensor.slunecni_radiace title: Meteo stanice hours_to_show: 12
5) finally, a preview of the functionality of my MQTT server using MQTT Eplorer
RE: Home Assistant - hornychz - 22-11-2024
I'll add: this is what my weather data page in HA looks like as of today...
RE: Home Assistant - uncle_bob - 25-12-2024
(22-11-2024, 00:36)hornychz Wrote:  I'll add: this is what my weather data page in HA looks like as of today...
Nice! Looks a lot neater than mine Smile
