Setup 4Pro Rx, Compile and Touchscr issues - Printable Version
+--- Forum: 4Pro Weather Stations - Receivers (https://www.meteocercal.info/forum/forum-57.html)
+---- Forum: User support forum for 4Pro Weather Station Receivers (https://www.meteocercal.info/forum/forum-61.html)
+---- Thread: Setup 4Pro Rx, Compile and Touchscr issues (/thread-2124.html)
RE: Setup 4Pro Rx, Compile and Touchscr issues - werk_ag - 23-01-2022
Hello Wim-T,
I'm also using winRAR, but a quite old version (3.93). Don't know if this could be the problem.
Could you please reupload it in ZIP format?
RE: Setup 4Pro Rx, Compile and Touchscr issues - Wim-T - 24-01-2022
(23-01-2022, 22:55)Werk_AG Wrote:  Hello Wim-T,
Hello Werk_AG,
Find in the attachments my reupload nl_NL_UTF8.h in ZIP format.
With kind regards,
Wim
RE: Setup 4Pro Rx, Compile and Touchscr issues - werk_ag - 25-01-2022
Hello Wim,
Your updated Dutch translation will be included on next releases of the 4Pro DB firmware.
Thank you very much for your collaboration.
Caneira
RE: Setup 4Pro Rx, Compile and Touchscr issues - Nmweather - 13-11-2022
Hello all, I am having issues with the touchscreen on my receiver, it is quite unresponsive to touch, typically requiring several taps in one spot to select a function or advance to the next screen. I loaded the calibration file and copied the numbers in the serial monitor then uncommented the calibration data  line in the touchscreen calibration section and inserted my calibration data but now it does not compile? It will compile with the data commented out.
I put the data in here:
//--------------------------------------------------------- //     Touch screen calibration //---------------------------------------------------------   uint16_t calData[5];   if (ExternalEeprom_readInt(CalibDone_Eeprom_adr) != 1) touch_calibrate();   #if (DISPLAY_TYPE == 1)     uint16_t calData[5] = { 502, 3216, 520, 3021, 1 };     for (uint8_t i = 0; i < 5; i++)      {        calData[i] = ExternalEeprom_readInt(CalibData1_Eeprom_adr + (i*2));        delay(10);      }   #endif   tft.setTouch(calData);[/i]
I get this error message, is it possible it has something to do with the libraries?
[i]Arduino: 1.8.19 (Mac OS X), Board: "MH ET LIVE ESP32MiniKit, 80MHz, Default with spiffs, 921600, None, Disabled" /Users/user/Documents/Weatherduino/WeatherDuino_4PRO_DB-6 b-010/firmware/WeatherDuino_4PESP32_RX_v6.2_b010/WeatherDuino_4PESP32_RX_v6.2_b010.ino: In function 'void setup()': WeatherDuino_4PESP32_RX_v6.2_b010:653:23: error: redeclaration of 'uint16_t calData [5]'      uint16_t calData[5] = { 502, 3216, 520, 3021, 1 };                        ^ /Users/user/Documents/Weatherduino/WeatherDuino_4PRO_DB-6 b-010/firmware/WeatherDuino_4PESP32_RX_v6.2_b010/WeatherDuino_4PESP32_RX_v6.2_b010.ino:649:12: note: 'uint16_t calData [5]' previously declared here    uint16_t calData[5];             ^~~~~~~ Multiple libraries were found for "WiFi.h"  Used: /Users/user/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFi  Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi  Not used: /Users/user/Documents/Arduino/libraries/WiFiEspAT Multiple libraries were found for "RH_RF95.h"  Used: /Users/user/Documents/Arduino/libraries/RadioHead_v1.119  Not used: /Users/user/Documents/Arduino/libraries/RadioHead_v1.121 Multiple libraries were found for "TimeLib.h"  Used: /Users/user/Documents/Arduino/libraries/Time-master  Not used: /Users/user/Documents/Arduino/libraries/Time Multiple libraries were found for "WebServer.h"  Used: /Users/user/Library/Arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WebServer  Not used: /Users/user/Documents/Arduino/libraries/ESPEssentials exit status 1 redeclaration of 'uint16_t calData [5]'[/i]
Not sure what I'm doing wrong but the touch issues make it quite tricky to use so any help is appreciated,
Thanks!
RE: Setup 4Pro Rx, Compile and Touchscr issues - werk_ag - 15-11-2022
Currently the WeatherDuino 4Pro Dual Band Receiver firmware automatically calls the touch screen calibration routine at first time it runs, and stores the calibration data on EEPROM. After that, to perform (and store) a new calibration data at startup, a byte must be cleared on the EEPROM at address 5330.
The easier way to do it is using the little utility attached bellow. After run it, reprogram the WeatherDuino 4Pro Dual Band Receiver. On first restart the receiver will ask you to perform a touch screen calibration. Calibration data will be stored on EEPRON. On next restarts or reboots, the screen calibration routine will not be show again. So do it carefully on first restart after having using the ClearTouchScreenCalibrationFlag utility.
RE: Setup 4Pro Rx, Compile and Touchscr issues - Nmweather - 03-12-2022
Thanks, that fixed it, it is much more responsive to finger inputs now.
I'm also experiencing periodic crashes of the receiver, I made sure to compile the software with the included libraries and used the esp 2.0.5, is there anything else to check?
Thanks in advance,
Zac
RE: Setup 4Pro Rx, Compile and Touchscr issues - werk_ag - 03-12-2022
(03-12-2022, 02:08)Nmweather Wrote:  Thanks, that fixed it, it is much more responsive to finger inputs now.
Hi Zac,
Is good to know, thank you.
(03-12-2022, 02:08)Nmweather Wrote:  I'm also experiencing periodic crashes of the receiver, I made sure to compile the software with the included libraries and used the esp 2.0.5, is there anything else to check?
Please open a new thread describing this issue the best was possible. I may need your Config_Opting.h file to try to reproduce it.
Latest firmware show system uptime also on the webpage.
