protect your connectors: amazing sealing compound - Printable Version
+--- Thread: protect your connectors: amazing sealing compound (/thread-2030.html)
RE: protect your connectors: amazing sealing compound - edr1924 - 26-06-2021
I bought it at a shop which doesn't sell it anymore. Confused
Conrad FRANCE (close to portugal so hopefully low shipping?) does sell it for 17 euro's.
The UK is outside of Europe so too expensive
If you want to look for it, please search for this: cellpack 240358
RE: protect your connectors: amazing sealing compound - engolling - 30-06-2021
I think you can buy similar stuff pretty easy as car body sealant.
For example:
https://eshop.wuerth.de/Produktkategorien/Knetplast/14013003020202.cyid/1401.cgid/de/DE/EUR/?CatalogCategoryRef=14013003020202%40WuerthGroup-Wuerth-1401&SelectedFilterAttribut=%255B%255D
The link is just an example and should be no advertising.
Nevertheless in my opinion connectors should always be chosen to withstand the environmental conditions within the expected lifetime.
Such products may only be an workaround for plugs that are manufacturer given Smile
Best regards
RE: protect your connectors: amazing sealing compound - edr1924 - 02-07-2021
(30-06-2021, 15:56)engolling Wrote:  I think you can buy similar stuff pretty easy as car body sealant.
For example:
Best regards
Thank you for you insight Engolling, and you are absolutely right when you say that it's best to use the right connectors.
But as I had this great stuff I use it when I can... Wink
Erik
RE: protect your connectors: amazing sealing compound - engolling - 02-07-2021
I confess I also use it sealing a cable gland which has a too big diameter for the cable going through Blush Like
