Work in progress on my new WX - Printable Version
+-- Forum: Weather Equipment - General Discussion (https://www.meteocercal.info/forum/Forum-Weather-Equipment-General-Discussion)
+--- Forum: Weather Stations, Info and Docs (https://www.meteocercal.info/forum/Forum-Weather-Stations-Info-and-Docs)
+--- Thread: Work in progress on my new WX (/Thread-Work-in-progress-on-my-new-WX)
RE: Work in progress on my new WX - qldbureau - 24-09-2018
Wonderful skill and quality in assemblies. Everything lines up perfectly!
RE: Work in progress on my new WX - engolling - 24-09-2018
Very nice setup! I'm jealous, that have welding equipment and now how to do it.
Another question - do you have your tipping bucket heated?
RE: Work in progress on my new WX - ok2arm - 25-09-2018
(24-09-2018, 00:42)41south Wrote:  Excellent craftsmanship to which I can only aspire!
I assume that the dome in the top of the right hand pagoda houses the UV sensor? What material did you use for it that allows UV to penetrate well?
is cover from outdoor moove sensor. Have little bit atteunation,but output signal from sensor is still to high...
(24-09-2018, 12:32)engolling Wrote:  Very nice setup! I'm jealous, that have welding equipment and now how to do it.
Not jet now, but will be... I use some resistors under cover or self adhesive heated foil, we will see...
RE: Work in progress on my new WX - engolling - 25-09-2018
If you are interested - my solution:
[Image: y4mHxqMWQH5A6ZNBGLQiyJPDcHmpladVH2NWiwPg...pmode=none]
[Image: y4mq_l8RRM6Sk6-pYidhFIubn1tgiIT-XPTGc0FO...pmode=none]
2x 33 Ohm Resistor in parallel, means 9W heating power @ 12V.
The thermistor for heater control is glued onto the funnel of the bucket.
The heater is controlled by a W1209 heating controller which is available from china very cheap. The system works fine since fall 2016/2017  Smile .
RE: Work in progress on my new WX - ok2arm - 08-12-2019
[attachment=2060]Here is my first demo of housig for client station
RE: Work in progress on my new WX - hornychz - 08-12-2019
Like Cool
RE: Work in progress on my new WX - werk_ag - 08-12-2019
Nice box. Looks good. Like
RE: Work in progress on my new WX - ok2arm - 20-02-2020
Display mounted on homephone
[attachment=2199]
[attachment=2200]
RE: Work in progress on my new WX - werk_ag - 21-02-2020
Wonderful! A custom designed case, I think?
Every time, and right before you leave your house you can see how the weather is. Like
I love and always loved the WiFi Wireless Display units.
