Mega 2560 problem - Printable Version
+--- Thread: Mega 2560 problem (
/thread-1354.html)
RE: Mega 2560 problem -
AllanG - 02-04-2018
Quote:uncle_bob wrote:
I'm wondering if the com port is already in use when trying to upload the sketch. That seems like the behavior is the Serial Monitor is still running when you try to upload.
You're right, there have been one or two occasions when I've not left enough time for the 2560 to "time out" before trying another upload and the com port has been busy. Most times it hasn't though.
Quote:Werk_AG wrote:
Hello Allan
My best sugestion is to try to start CumulusMX with the Data Logger disabled, and check if there is normal comunication.
Edit the Cumulus.ini file and change this:
Yes, I remembered that little "trick" which was necessary before an earlier software update, so tried it a couple of days ago but it made no difference unfortunately.
I'll keep trying different things and report back when I find something. Thanks for the help and suggestions guys, very much appreciated.
Allan
JT118 - 21-03-2020
These seem to be in short supply;
https://www.ebay.co.uk/itm/Mega2560-R3-PRO-Module-CH340G-ATMEGA2560-16AU-Chip-With-Male-Pin-For-T3/193362822037?
Could they be replaced by:
https://www.ebay.co.uk/itm/MEGA-2560-Pro-Embedded-USB-CH340G-ATMEGA2560-16AU-Chip-for-arduino-Mega-2560-R3/273635941803?
werk_ag - 21-03-2020
(21-03-2020, 10:38)JT118 Wrote: These seem to be in short supply;
No, the two boards don't have the same pinout.
JT118 - 21-03-2020
OK; maybe it is just an ebay thing, but not many on ebay.co.uk. I expect they will reappear.
Plenty available from original manufacturer eBay store:
https://www.ebay.co.uk/itm/New-Small-Meduino-Mega2560-R3-Pro-Mini-ATMEGA16U2-Arduino-Mega2560-Compatible/162593120251?hash=item25db4e1ffb:g:-9cAAOSwyQtVnMbp
JT118 - 23-03-2020
Could you advise on R1 on the Pro2Plus RX board v2.00. On the parts list it is stated as 4R. I am struggling to find an SMD rated at 4R (plenty at 4R3). Is this a critical component?
engolling - 23-03-2020
Hi JT,
in my parts list as well in the schematics R1 is a 0Ohm brigde.
Are you sure you mean R1 and if yes, where did you find the 4 Ohm?
Stefan
JT118 - 23-03-2020
That makes more sense thanks; It was in these two that R1 = 4 ohms
https://www.meteocercal.info/forum/attachment.php?aid=1136
https://www.meteocercal.info/forum/Thread-WeatherDuino-Pro2-PLUS-RX-2-xx-Parts-List
Or maybe I am misreading things.
Seems to me that I have another revision of the parts list or I looked wrong
In the end - I think Werk has to tell us
laulau - 23-03-2020
At some point i had this with 0 Ohm :
