Troubleshooting RX board - Printable Version
+--- Thread: Troubleshooting RX board (/thread-1325.html)
Pages: 1 2 3 4
RE: Troubleshooting RX board - ok2arm - 28-01-2018
Hi Zdenek,
sry but, when I insert code, paste and post, the forum ask me " this message is a spam and not use...." :/
I check again the TX adress
About the last version... When I use last version (5) have some err bettwen compilation... See bellow
Sry, I Am not able insert "code" :/
Arduino: 1.8.5 (Windows 7), Vývojová deska: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)" WeatherDuinoPro2Plus_RX_v500_b002:521: error: expected constructor, destructor, or type conversion before '(' token    pinMode(TFT_RST, OUTPUT); digitalWrite(TFT_RST, LOW);   // Reset Display           ^ WeatherDuinoPro2Plus_RX_v500_b002:521: error: expected constructor, destructor, or type conversion before '(' token    pinMode(TFT_RST, OUTPUT); digitalWrite(TFT_RST, LOW);   // Reset Display                                          ^ WeatherDuinoPro2Plus_RX_v500_b002:522: error: expected constructor, destructor, or type conversion before '(' token    delay(200);         ^ WeatherDuinoPro2Plus_RX_v500_b002:523: error: expected constructor, destructor, or type conversion before '(' token    digitalWrite(TFT_RST, HIGH);                                      ^ WeatherDuinoPro2Plus_RX_v500_b002:524: error: expected constructor, destructor, or type conversion before '(' token    delay(200);         ^ WeatherDuinoPro2Plus_RX_v500_b002:541: error: 'tft' does not name a type    tft.init();    ^ WeatherDuinoPro2Plus_RX_v500_b002:542: error: 'tft' does not name a type    tft.setRotation(3);    ^ WeatherDuinoPro2Plus_RX_v500_b002:543: error: 'tft' does not name a type    tft.setTextWrap(false);    ^ WeatherDuinoPro2Plus_RX_v500_b002:545: error: 'touch' does not name a type      touch.begin();      ^ WeatherDuinoPro2Plus_RX_v500_b002:556: error: 'dataflash' does not name a type      dataflash.setup(FLASH_CS);  // Flash CS line      ^ WeatherDuinoPro2Plus_RX_v500_b002:557: error: expected constructor, destructor, or type conversion before '(' token      delay(10);           ^ WeatherDuinoPro2Plus_RX_v500_b002:558: error: 'dataflash' does not name a type      dataflash.begin();      ^ WeatherDuinoPro2Plus_RX_v500_b002:567: error: expected constructor, destructor, or type conversion before '(' token    memcpy(&loopData, &loopInit, sizeof(loopInit));          ^ WeatherDuinoPro2Plus_RX_v500_b002:568: error: expected constructor, destructor, or type conversion before '(' token    memcpy(&loop2Data, &loop2Init, sizeof(loop2Init));          ^ WeatherDuinoPro2Plus_RX_v500_b002:571: error: 'sCmd' does not name a type    sCmd.addCommand("LOOP", cmdLoop);           // Send the loop data    ^ WeatherDuinoPro2Plus_RX_v500_b002:572: error: 'sCmd' does not name a type    sCmd.addCommand("LPS", cmdLoop2);           // Send the loop2 data    ^ WeatherDuinoPro2Plus_RX_v500_b002:573: error: 'sCmd' does not name a type    sCmd.addCommand("NVER", cmdNver);           // Send the version string    ^ WeatherDuinoPro2Plus_RX_v500_b002:575: error: 'sCmd' does not name a type    sCmd.addCommand("VER", cmdVer);             // Send the associated date for this version    ^ WeatherDuinoPro2Plus_RX_v500_b002:576: error: 'sCmd' does not name a type    sCmd.addCommand("WRD\x12M", cmdWRD);        // Support the Davis legacy "WRD" command    ^ WeatherDuinoPro2Plus_RX_v500_b002:577: error: 'sCmd' does not name a type    sCmd.addCommand("GETTIME", cmdGettime);     // Send back current RTC date/time    ^ WeatherDuinoPro2Plus_RX_v500_b002:578: error: 'sCmd' does not name a type    sCmd.addCommand("SETTIME", cmdSettime);     // Update current RTC date/time from PC    ^ WeatherDuinoPro2Plus_RX_v500_b002:579: error: 'sCmd' does not name a type    sCmd.addCommand("EEBRD", cmdEebrd);         // EEPROM Read    ^ WeatherDuinoPro2Plus_RX_v500_b002:580: error: 'sCmd' does not name a type    sCmd.setDefaultHandler(cmdUnrecognized);    // Handler for command that isn't matched    ^ WeatherDuinoPro2Plus_RX_v500_b002:581: error: 'sCmd' does not name a type    sCmd.setNullHandler(cmdWake);               // Handler for an empty line to wake the simulated console    ^ WeatherDuinoPro2Plus_RX_v500_b002:582: error: 'sCmd' does not name a type    sCmd.addCommand("RXCHECK", cmdRxCheck);     // RX diagnostics (Implementated just to avoid error on the logs)    ^ WeatherDuinoPro2Plus_RX_v500_b002:583: error: 'sCmd' does not name a type    sCmd.addCommand("BARDATA", cmdBardata);     // Barometer calibration data    ^ WeatherDuinoPro2Plus_RX_v500_b002:585: error: 'sCmd' does not name a type    sCmd.addCommand("DMPAFT", cmdDmpaft);       // Download archive records after date:time specified    ^ WeatherDuinoPro2Plus_RX_v500_b002:586: error: 'sCmd' does not name a type    sCmd.addCommand("SETPER", cmdSetper);       // Set archive interval period    ^ WeatherDuinoPro2Plus_RX_v500_b002:587: error: 'PageToWrite' does not name a type    PageToWrite = ExternalEeprom_readInt(PageToWrite_Eeprom_adr);    ^ WeatherDuinoPro2Plus_RX_v500_b002:591: error: expected unqualified-id before 'if'    if ((ExternalEeprom_read(SoftwareVersion_Eeprom_adr) != SoftwareVersion) || (ExternalEeprom_read(SoftwareBuild_Eeprom_adr) != SoftwareBuild) )    ^ exit status 1 expected constructor, destructor, or type conversion before '(' token WeatherDuinoPro2Plus_RX_v500_b002:521: error: expected constructor, destructor, or type conversion before '(' token    pinMode(TFT_RST, OUTPUT); digitalWrite(TFT_RST, LOW);   // Reset Display           ^ WeatherDuinoPro2Plus_RX_v500_b002:521: error: expected constructor, destructor, or type conversion before '(' token    pinMode(TFT_RST, OUTPUT); digitalWrite(TFT_RST, LOW);   // Reset Display                                          ^ WeatherDuinoPro2Plus_RX_v500_b002:522: error: expected constructor, destructor, or type conversion before '(' token    delay(200);         ^ WeatherDuinoPro2Plus_RX_v500_b002:523: error: expected constructor, destructor, or type conversion before '(' token    digitalWrite(TFT_RST, HIGH);                                      ^ WeatherDuinoPro2Plus_RX_v500_b002:524: error: expected constructor, destructor, or type conversion before '(' token    delay(200);         ^ WeatherDuinoPro2Plus_RX_v500_b002:541: error: 'tft' does not name a type    tft.init();    ^ WeatherDuinoPro2Plus_RX_v500_b002:542: error: 'tft' does not name a type    tft.setRotation(3);    ^ WeatherDuinoPro2Plus_RX_v500_b002:543: error: 'tft' does not name a type    tft.setTextWrap(false);    ^ WeatherDuinoPro2Plus_RX_v500_b002:545: error: 'touch' does not name a type      touch.begin();      ^ WeatherDuinoPro2Plus_RX_v500_b002:556: error: 'dataflash' does not name a type      dataflash.setup(FLASH_CS);  // Flash CS line      ^ WeatherDuinoPro2Plus_RX_v500_b002:557: error: expected constructor, destructor, or type conversion before '(' token      delay(10);           ^ WeatherDuinoPro2Plus_RX_v500_b002:558: error: 'dataflash' does not name a type      dataflash.begin();      ^ WeatherDuinoPro2Plus_RX_v500_b002:567: error: expected constructor, destructor, or type conversion before '(' token    memcpy(&loopData, &loopInit, sizeof(loopInit));          ^ WeatherDuinoPro2Plus_RX_v500_b002:568: error: expected constructor, destructor, or type conversion before '(' token    memcpy(&loop2Data, &loop2Init, sizeof(loop2Init));          ^ WeatherDuinoPro2Plus_RX_v500_b002:571: error: 'sCmd' does not name a type    sCmd.addCommand("LOOP", cmdLoop);           // Send the loop data    ^ WeatherDuinoPro2Plus_RX_v500_b002:572: error: 'sCmd' does not name a type    sCmd.addCommand("LPS", cmdLoop2);           // Send the loop2 data    ^ WeatherDuinoPro2Plus_RX_v500_b002:573: error: 'sCmd' does not name a type    sCmd.addCommand("NVER", cmdNver);           // Send the version string    ^ WeatherDuinoPro2Plus_RX_v500_b002:575: error: 'sCmd' does not name a type    sCmd.addCommand("VER", cmdVer);             // Send the associated date for this version    ^ WeatherDuinoPro2Plus_RX_v500_b002:576: error: 'sCmd' does not name a type    sCmd.addCommand("WRD\x12M", cmdWRD);        // Support the Davis legacy "WRD" command    ^ WeatherDuinoPro2Plus_RX_v500_b002:577: error: 'sCmd' does not name a type    sCmd.addCommand("GETTIME", cmdGettime);     // Send back current RTC date/time    ^ WeatherDuinoPro2Plus_RX_v500_b002:578: error: 'sCmd' does not name a type    sCmd.addCommand("SETTIME", cmdSettime);     // Update current RTC date/time from PC    ^ WeatherDuinoPro2Plus_RX_v500_b002:579: error: 'sCmd' does not name a type    sCmd.addCommand("EEBRD", cmdEebrd);         // EEPROM Read    ^ WeatherDuinoPro2Plus_RX_v500_b002:580: error: 'sCmd' does not name a type    sCmd.setDefaultHandler(cmdUnrecognized);    // Handler for command that isn't matched    ^ WeatherDuinoPro2Plus_RX_v500_b002:581: error: 'sCmd' does not name a type    sCmd.setNullHandler(cmdWake);               // Handler for an empty line to wake the simulated console    ^ WeatherDuinoPro2Plus_RX_v500_b002:582: error: 'sCmd' does not name a type    sCmd.addCommand("RXCHECK", cmdRxCheck);     // RX diagnostics (Implementated just to avoid error on the logs)    ^ WeatherDuinoPro2Plus_RX_v500_b002:583: error: 'sCmd' does not name a type    sCmd.addCommand("BARDATA", cmdBardata);     // Barometer calibration data    ^ WeatherDuinoPro2Plus_RX_v500_b002:585: error: 'sCmd' does not name a type    sCmd.addCommand("DMPAFT", cmdDmpaft);       // Download archive records after date:time specified    ^ WeatherDuinoPro2Plus_RX_v500_b002:586: error: 'sCmd' does not name a type    sCmd.addCommand("SETPER", cmdSetper);       // Set archive interval period    ^ WeatherDuinoPro2Plus_RX_v500_b002:587: error: 'PageToWrite' does not name a type    PageToWrite = ExternalEeprom_readInt(PageToWrite_Eeprom_adr);    ^ WeatherDuinoPro2Plus_RX_v500_b002:591: error: expected unqualified-id before 'if'    if ((ExternalEeprom_read(SoftwareVersion_Eeprom_adr) != SoftwareVersion) || (ExternalEeprom_read(SoftwareBuild_Eeprom_adr) != SoftwareBuild) )    ^ exit status 1 expected constructor, destructor, or type conversion before '(' token Táto zpráva by měla mít víc informacií v "Zobrazení podrobného výstupu při kompilaci" podle zapnuté volby v Soubor -> Nastavení.
RE: Troubleshooting RX board - werk_ag - 29-01-2018
(28-01-2018, 18:12)ok2arm Wrote:  Now is board without the sensors, I need not connect board between themselves...
I think this is the clue for what is happening...
In your TX config you have defined a SHT31 sensor, if it is not installed, the TX board is not transmitting anything (I bet the TX LED is not blinking), because it is in a loop trying to read the sensor.
To test the system, at least you have to install a temp/hum sensor on the TX board and define the correct type.
Also, the RX system will never leave the initial screen until it receives data from the TX unit.
(28-01-2018, 18:12)ok2arm Wrote:  TX board I think also - question - the value from TMP36 is also see on the display in RX ?
Yes, but only after is being able to receive data (temp/hum, wind and rain) from the TX unit. Until the RX can get these data, it don't fully initialize, and stays at the initial screen
RE: Troubleshooting RX board - russellb - 12-07-2018
[attachment=1511][attachment=1511]
More Rx Board problems, I'm afraid.
There appear to be 2 issues:
1. The COM LED (green in the accompanying pictures) stays alight.
2. I also have the display problem, but I presume the software is looping, as it goes white for a few seconds about every 40 seconds.
// -------------------------------------------------------------------------------------- //  WeatherDuino Pro2 PLUS Receiver - Version: P2AT2560_RX_v6.0_b014 //                 Start of user configurable options // -------------------------------------------------------------------------------------- // If you need help about any of the user configurable settings, please first do a search // at the WeatherDuino Pro2 support forum. If you don't find any relevant info, then post // a new thread. // // -------------------------------------------------------------------------------------- //   Define Name and ID's for this weather station // -------------------------------------------------------------------------------------- const char* WeatherStation_Name = "XXXXXX XXXXX"; // Put here an unique identifier as your Weather Station name - Don't leave empty or default #define Station_ID  0xA1       // Station_ID, use the same value in all TX units #define Relay_ID    0xA3       // Relay_ID,   use the same value in all WD units // -------------------------------------------------------------------------------------- //   Define your Weather Station location. Use decimal format for Latitude and Longitude // -------------------------------------------------------------------------------------- #define LATITUDE      -33.1    // Put here your Station latitude in degrees North (always use 3 decimal places) #define LONGITUDE     151.5    // Put here your Station longitude in degrees - minus for West (always use 3 decimal places) #define ELEVATION     50      // Put here your Station height above sea level in Meters (no decimal places) // -------------------------------------------------------------------------------------- //   Define rules for Auto Summer Time Display, and clock adjustment // -------------------------------------------------------------------------------------- // Example for Australia Eastern Time Zone (Sydney, Melbourne) // TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours // TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours // Timezone myTZ(aEDT, aEST); TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660};    //UTC + 11 hours TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600};    //UTC + 10 hours Timezone myTZ(aEDT, aEST); // -------------------------------------------------------------------------------------- //   Define Interface Language // --------------------------------------------------------------------------------------       #include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end                              // Currently available languages: en_GB, fr_FR, de_DE, pt_PT, es_ES, cs_CZ, nl_NL, it_IT // -------------------------------------------------------------------------------------- //   Define Roll Over Hour for Meteorological Day // -------------------------------------------------------------------------------------- const byte MeteoDay_HStart = 9;    // Use values from 0 to 23 // -------------------------------------------------------------------------------------- //   Define Display Backlight TimeOut // -------------------------------------------------------------------------------------- #define BACKLIGHT_TIMEOUT     0    // Timeout for display backlight in minutes (1 to 255). 0 = Always ON #define USE_BIGCLOCK          1    // Instead of turn off TFT backlight, show a big clock screen. 0= No, 1= Yes // -------------------------------------------------------------------------------------- //   Define data display units // -------------------------------------------------------------------------------------- #define DATE_TIME_FORMAT  0    // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd #define TEMP_DISPLAY_UNIT 0    // 0 for ºC, 1 for ºF #define ATM_DISPLAY_UNIT  0    // 0 for mBar, 1 for inHg #define RAIN_DISPLAY_UNIT 0    // 0 for mm, 1 for inches #define WIND_DISPLAY_UNIT 0    // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots // -------------------------------------------------------------------------------------- //   Define the type of your Barometric Pressure Sensor // -------------------------------------------------------------------------------------- #define BAROMETRIC_SENSOR  0   // 0= BME280, 1= BMP280 2= BMP085 / BMP180 // -------------------------------------------------------------------------------------- //   Define the type of your inside Temperature / Humidity Sensor // -------------------------------------------------------------------------------------- #define INSIDE_TH_SENSOR   0   // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31 // -------------------------------------------------------------------------------------- //   Fine adjusts for Inside Temperature and Barometer // -------------------------------------------------------------------------------------- const int   TemperaturaInt_offset =   0;   // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC) const float pressure_offset       =   0;   // Pressure Fine Adjust in mB // -------------------------------------------------------------------------------------- //   Define Wind Speed and Wind Gust resolution - Read carefully // -------------------------------------------------------------------------------------- // This setting only have effect when the software is used in Davis VP emulation mode #define VP2_WIND_RESOLUTION     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h                                     // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h                                     // WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,                                     // but also limits both of them, to a maximum reading of just 91.8 Km/h                                     // If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).                                     // Weather Display users should set this option to 0 - Standard Davis wind resolution   // -------------------------------------------------------------------------------------- //   Define use of Wind Gust Spike prevention routines (mostly for FO anemometers) // -------------------------------------------------------------------------------------- #define WIND_SPIKECONTROL 1   // 0= Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define the source of your main outside sensors // -------------------------------------------------------------------------------------- // ---- If you are using just one TX board, the source for all items should be equal to your single TX Unit ID (most likely zero). // ---- Define the source of your main Temperature / Humidity sensor #define TH_SOURCE       0   // 0= Temp/Hum sensor connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Temp / Hum // ---- Define the source of your Main Wind sensor #define WIND_SOURCE     0   // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Wind Speed & Dir // ---- Define the source of your main Rain Gauge #define RAIN_SOURCE     0   // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, ..., 3 for Auriol RF Rain Gauge // ---- Define the source of your main Solar Radiation sensor #define SOLAR_SOURCE    9   // 0= Solar Radiation sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // ---- Define the source of your main UV sensor #define UV_SOURCE       9  // 0= UV sensor connected to TX_Unit 0, 1= for TX_Unit1, ..., 9 for not used // -------------------------------------------------------------------------------------- //   Each TX unit can send data from two Temp / Hum sensors. //   Here you must define which one will be used as your main outside Temperature / Humidity Sensor //   SENSOR_0 can be any of the supported I2C T/H sensors (SHT31, SHT21 or HTU21D), SENSOR_1 can be an SHT1x or DHT22 // -------------------------------------------------------------------------------------- #define MAINOUT_TH_SENSOR 0   // 0 for SENSOR_0, 1 for SENSOR_1 // -------------------------------------------------------------------------------------- //   Define the type of your Solar Radiation device // -------------------------------------------------------------------------------------- #define SOLAR_SENSOR     2   // 1= Solar Cell "Pyranometer", 2= Apogee SP-110 Pyranometer, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor                             // ---- Support for sensor type 4 is experimental (type 4 is a PAR sensor) // -------------------------------------------------------------------------------------- //   Define the type of your UV device // -------------------------------------------------------------------------------------- #define UV_SENSOR        1          // 1= UVM-30A, 2= VEML6075, 3= Reserved const byte UV_Transmission = 65;    // UV Transmission percentage of UV sensor cover material. // -------------------------------------------------------------------------------------- //   Extra Sensors Settings and Mapping // -------------------------------------------------------------------------------------- // ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used. //      Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1 // // ---- Source 0 means TX unit0, 1 means TX unit1... // ---- Source 6 (Reserved) // ---- Source 7 is for BIOS Sensor (Only Temperature is shown) // ---- Source 8 is for Temperature/Humidity from the Air Quality Monitor // // ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units) // ---- Example: // ----                          ES0   ES1   ES2   ES3   ES4   ES5   ES6     //#define EXTRASENSORS_SOURCE { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{9,9} } //               {0,0} - First extra sensor (ES0), will be sensor 0 from TX unit0 //               {0,1} - Second extra sensor (ES1), will be sensor 1 from TX unit0 //               {1,0} - Third extra sensor (ES2), will be sensor 0 from TX unit1 //               {9,9} - Fourth extra sensor (ES3), not used - not mapped //               {9,9} - Fifth extra sensor (ES4), not use - not mapped //               {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor //               {9,9} - Seventh extra sensor (ES6), not use - not mapped // //-----                        ES0   ES1   ES2   ES3   ES4   ES5   ES6     #define EXTRASENSORS_SOURCE { {9,9},{9,9},{9,9},{9,9},{9,9},{9,9},{8,0} } // ---- Define personalized names for each Extra sensor. Attention, 8 chars maximum // ---- There is no need to define a name for the Extra Sensor mapped to the Dust Density / AQI index data //                   Max. Size  [--------] const char ESname_1[] PROGMEM = "";            // 8 chars max const char ESname_2[] PROGMEM = "";            // 8 chars max const char ESname_3[] PROGMEM = "";            // 8 chars max const char ESname_4[] PROGMEM = "";            // 8 chars max const char ESname_5[] PROGMEM = "";            // 8 chars max const char ESname_6[] PROGMEM = "";            // 8 chars max const char ESname_7[] PROGMEM = "Dust TH";     // 8 chars max // -------------------------------------------------------------------------------------- //   BIOS soil moisture sensor settings // -------------------------------------------------------------------------------------- // ---- Please use the included BIOS_ID_Scanner sketch to find you BIOS Device ID #define BIOS_SENSOR_ID   0   // Device ID in HEX format, or 0 not used // -------------------------------------------------------------------------------------- //   Soil / Leaf Interface Settings and Sensors Mapping //   (The mapping logic is the same than used with the Extra Sensors) // -------------------------------------------------------------------------------------- // 0 = Soil Leaf Interface not used // 1 = Soil Leaf Interface connected to a TX unit #define SOIL_LEAF_INTERFACE  0   // 0, 1, // ---- For Soil & Leaf data from SoilLeaf_Interface wired to a TX unit, use TX Unit number as source // ---- For BIOS Soil Temp / Moisture use 7 as source // ---- To disable use 9 in both fields //                                 S1    S2    S3    S4 #define SOILTEMPSENSORS_SOURCE  { {9,9},{9,9},{9,9},{9,9} } #define LEAFTEMPSENSORS_SOURCE  { {9,9},{9,9},{9,9},{9,9} } #define SOILMOISTSENSORS_SOURCE { {9,9},{9,9},{9,9},{9,9} } #define LEAFWETSENSORS_SOURCE   { {9,9},{9,9},{9,9},{9,9} } // ---- Define personalized names for each Soil and Leaf sensor. Attention, 8 chars maximum //              Soil Max. Size  [--------] const char SSname_1[] PROGMEM = "1";        // 8 chars max const char SSname_2[] PROGMEM = "2";        // 8 chars max const char SSname_3[] PROGMEM = "3";        // 8 chars max const char SSname_4[] PROGMEM = "4";        // 8 chars max //              Leaf Max. Size  [--------] const char LSname_1[] PROGMEM = "1";        // 8 chars max const char LSname_2[] PROGMEM = "2";        // 8 chars max const char LSname_3[] PROGMEM = "3";        // 8 chars max const char LSname_4[] PROGMEM = "4";        // 8 chars max // Define VWC calculation method // Method 1 applies only for VH400 soil moisture sensor // // METHOD 1 - Conversion from voltage to VWC (volumetric water content) is done using the piecewise regressions provided by the manufacturer // at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml // // METHOD 2 - Used for any sensor which have a linear output between voltage and VWC (0V=0VWC, maxV=100VWC) . #define VWC_CALCMETHOD   1  // 1 or 2 // Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface // Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry) //                                                  ADC1  ADC2  ADC3  ADC4   const uint16_t AnalogSensor_MaxVoltOut[4]   = { 3000, 1395, 5000, 5000 };    // Values in miliVolts const uint16_t AnalogSensor_MinVoltOut[4]   = {    0,  530,    0,    0 }; // -------------------------------------------------------------------------------------- //   Broadacasting settings for Wireless Display Units // -------------------------------------------------------------------------------------- #define RELAY_DATA       1   // 0= Disables Data Relay, 1= Enables Data Relay // -------------------------------------------------------------------------------------- //   Davis compatible Data Logger Settings // -------------------------------------------------------------------------------------- #define LOGGER_ENABLE    1   // 0= Disable 1= Enable byte ARCHIVE_PERIOD  =   5;  // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30) // -------------------------------------------------------------------------------------- //   Define type of your Weather Software // -------------------------------------------------------------------------------------- #define WEATHERSOFT      1   // 0= CumulusMX, 1= Any other (Cumulus 1, WeewX, Weather Display, etc.) // -------------------------------------------------------------------------------------- //   Easyweather Mode output // -------------------------------------------------------------------------------------- #define EASYWEATHER_OUT  0   // 0= Disable (defaut) 1= Enable // -------------------------------------------------------------------------------------- //   Internet Settings // -------------------------------------------------------------------------------------- #define ENABLE_INTERNET     1                        // 1= Enable Internet connection, 0= Disable // ---- NTP Settings ---- #define ENABLE_NTP          1                        // 1= Enable Sync time with NTP servers, 0= Disable // NTP Servers: #define TIMESERVER "pool.ntp.org" //#define TIMESERVER "time.nist.gov"                 // ntp1.nl.net NTP server //#define TIMESERVER "80.96.196.58"                  // timp.mcsi.ro //#define TIMESERVER "193.79.237.14"                 // ntp1.nl.net NTP server // ---- Weather Wunderground Settings ---- #define ENABLE_WU_UPLOAD   0                         // 1= Enable upload to Wunderground, 0= Disable #define WU_UPLOAD_INTEMP   0                         // 1= Enable upload of Inside Temperature / Humidity, 0= Disable byte    WU_upload_period = 4;                        // Period in minutes between uploads to WU (Should be >= 3 minutes, if less defaults to 4 minutes) // ---- Air Quality Monitor - Upload to ThingSpeak Settings ---- #define ENABLE_TS_UPLOAD         0                   // 1= Enable, 0= Disable // ---- Air Quality Monitor - Upload and insert data in a SQL table at your own server ---- // ---- Database and table must be created first. See AirQuality_LogToSQL.php script for info #define ENABLE_AQM_TO_MYSERVER    0                  // 1= Enable, 0= Disable // ---- Web Server Settings ---- #define ENABLE_WEBSERVER          0                  // 1= Enable 0= Disable #define WEBSERVER_PORT           80                  // WebServer port (default 80) // -------------------------------------------------------------------------------------- //   Enable / Disable GPIO routines - General Purpose Input / Output ports // -------------------------------------------------------------------------------------- #define USE_GPIO  0   // 0=Disable, 1= Enable // -------------------------------------------------------------------------------------- //   Define display order of data screens on the TFT //   Use sequentially numbers from 1 to 4. // -------------------------------------------------------------------------------------- #define AirQuality_Data    1 #define TXinfo_Data        2 #define ExtraSensors_Data  3 #define SoilLeaf_Data      4 // -------------------------------------------------------------------------------------- //   Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- bool Test_Mode = false;    // false= Normal working mode, true= Test mode only (no logger, no usb connection) // ************************************************************************************* //     Hardware Settings // ************************************************************************************* // -------------------------------------------------------------------------------------- //   Define PCB Version Number // -------------------------------------------------------------------------------------- //                              Take particular attention to this setting. //                              Your system may not work properly if you define a wrong pcb version number. //                              In case of doubt check what is printed in your pcb. #define PCB_VERSION   20   // PCB version number, without the decimal point Ex: 1.3 = 13 (integer number) // -------------------------------------------------------------------------------------- //   Define your Display type // -------------------------------------------------------------------------------------- #define DISPLAY_TYPE     3    // 1= LCD 20x4, 3= TFT 320x240 ILI9341 // -------------------------------------------------------------------------------------- //   Define Type of your Touch Panel (Aplies only to PCB Versions >= 20) // -------------------------------------------------------------------------------------- #define TOUCH_TYPE       3    // 3= Default Setting, 1= Alternative Setting (Yellow pin Displays) // -------------------------------------------------------------------------------------- //   Define LCD I2C address // -------------------------------------------------------------------------------------- // Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display // Default address will work most of the times! #define LCD_ADDRESS      0x27 //#define LCD_ADDRESS      0xC9   // -------------------------------------------------------------------------------------- //   SHT31 I2C Address - Default address will work most of the times! // -------------------------------------------------------------------------------------- #define SHT31_ADDRESS       0x44       // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- //   Presure Sensor Address (no need to change) // -------------------------------------------------------------------------------------- //#define BMP085_ADDRESS    0x77       // I2C address of BMP085 or BMP180 // -------------------------------------------------------------------------------------- //   Debug helper // -------------------------------------------------------------------------------------- //#define PRINT_DEBUG_WIFI //#define PRINT_DEBUG_NTP_UPDATE      // Prints to serial monitor messages related to sync time with NTP server //#define PRINT_DEBUG_WU_UPLOAD       // Prints to serial monitor messages related to Weather Underground upload. //#define PRINT_DEBUG_TS_UPLOAD //#define PRINT_DEBUG_MYSERVER_UPLOAD //#define PRINT_DEBUG_VCHECK //#define PRINT_DEBUG_TCP_SERVER //#define PRINT_DEBUG_AURIOL //#define PRINT_DEBUG_BIOS //#define PRINT_DEBUG_RF_MESSAGES // --------------------------------------------------------------------------------------------------- //     End of user configurable options // ---------------------------------------------------------------------------------------------------
Thanks for any help, I'm sure it's something I have overlooked.
RE: Troubleshooting RX board - werk_ag - 12-07-2018
Hi
Try change this:
to:
// -------------------------------------------------------------------------------------- //   Define Type of your Touch Panel (Aplies only to PCB Versions >= 20) // -------------------------------------------------------------------------------------- #define TOUCH_TYPE       1    // 3= Default Setting, 1= Alternative Setting (Yellow pin Displays)
This should solve the display issue. Hope that display isn't another unknown variant of the original ILI9341 TFT displays. Picture is quite different of the recommended version.
(12-07-2018, 03:59)Werk_AG Wrote:  Hi
Try change this
Unfortunately no real change. I have  a second (identical) display, and not surprisingly it behaves the same, so not a "one-off"
I've attached some pictures of the display board.
Can I do some debugging?
RE: Troubleshooting RX board - werk_ag - 13-07-2018
Just to try to discard possibilities, there is some things you can try.
Does your transmitter unit is already working and sending data? If not, try to start the receiver is test mode.
// -------------------------------------------------------------------------------------- //   Test Mode : Never run a live system in test mode // -------------------------------------------------------------------------------------- bool Test_Mode = true;    // false= Normal working mode, true= Test mode only (no logger, no usb connection)
You can also enable some of the debug options just to check if the unit initializes. Try first
// -------------------------------------------------------------------------------------- //   Debug helper // -------------------------------------------------------------------------------------- #define PRINT_DEBUG_WIFI #define PRINT_DEBUG_NTP_UPDATE      // Prints to serial monitor messages related to sync time with NTP server
What type of sensor are you using for ATM and inside T/H?
From your Config_Options.h it should be an BME280, is that right?
RE: Troubleshooting RX board - russellb - 13-07-2018
(13-07-2018, 03:32)Werk_AG Wrote:  Hi,
Yes, it's the BME280 as sensor.
Changing to test mode and enabling the debugging has at least made the COM LED intermittent, but display is still intermittent plain white.
The wi-fi is not showing up on scanning my network. Does it not work in "test" mode? Though trying with Test Mode=false I still can't see the wi-fi .
I've tried to copy serial monitor output as hex, but no luck
Serial monitor output: wJk??+? ??>?<bh:0f>???ZIII? XHZ<bh:0b>JJK??<bh:04>???ZyiYX?1)???s
I tried to run I2C _scanner also to see if I could find an address for the display board, but couldn't get anything useful
OK try this as hex output:
77 4A 6B 3F 3F 2B 3F 0D 0A 3F 3F 3E 3F 0F 3F 3F 3F 5A 49 49 49 3F 0D 58 48 5A 0B 4A 4A 4B 3F 3F 04 3F 3F 3F 5A 79 69 59 58 3F 31 29 3F 3F 3F 73
The debug output of serial monitor is human readable, try open it at 19200 baud.
Quote:The wi-fi is not showing up on scanning my network.
That is the normal behaviour, the device runs in ST (station) mode not in AP mode.
Do you have any Transmitter unit already sending data?
If you have a multimeter, try measure the output voltage of the 3.3V regulator.
RE: Troubleshooting RX board - russellb - 14-07-2018
(13-07-2018, 16:49)Werk_AG Wrote:  Hi,
OK works much better at 19200 baud.
I had already checked voltages, and 3.3 v seems OK.
BUT I found when checking the BME280 it was not plugged in.
I2C_scanner found a device at 0x50 so  I set that as display address.
I have put the Wi-Fi credentials in, but it's not showing on my network.
Debug output shows:
ESP8266 FW Version: Mode station ERR Multiple mux ERR Join AP failure WiFi connection is OFF
From what I can see "Internet" is enabled.
I presume I'm missing something.
There is a little blue LED near the Wi-Fi antenna which blinks on booting, and I have noted it flashing occasionally
