Wireless Display Fahrenheit off - Printable Version
+--- Thread: Wireless Display Fahrenheit off (/Thread-Wireless-Display-Fahrenheit-off)
RE: Wireless Display Fahrenheit off - werk_ag - 08-09-2017
Hi danner,
Please download the software package again, version number issue is now fixed.
Thank you
RE: Wireless Display Fahrenheit off - danner - 08-09-2017
Thanks, the proper version is now displayed, however, the inside temperature is still incorrect.
Are you using a local sensor, of receiving inside temperature from the main unit (WeatherDuino receiver)?
Edited: Sorry, I already have the answer from your PM.
RE: Wireless Display Fahrenheit off - danner - 09-09-2017
This is the sequence as it starts up. The actual temperature in my room is 67.6F.
[Image: thrXuaX.jpg]
[Image: A5y64Ek.jpg]
[Image: yXzaRzQ.jpg]
[Image: nCMnk10.jpg]
Not sure if this helps or not, but if I do not select the local temp sensor on the WD and instead tell it to use the indoor temp sensor from the Pro2+ receiver, then the displayed inside temperature is correct. Of course the temp is from the other room where the Pro2+ receiver is, but it is the correct temperature. When I change it back to use the local temp sensor, which is the first SHT35-D I ordered that came configured as 0x45, then the inside temp reads about 29F cooler than it should.
It appears that the WD update from WeatherDuino Pro2 PLUS WD v3.0_b008 now shows the correct local temperature at the WD.
I did notice, however, that the "Receiver Location T/H" on the System Info screen the temp and humidity read 0.0F 0.0%
Thanks for the fix for the main screen! Please don't worry about the System Info screen until you're settled.
RE: Wireless Display Fahrenheit off - werk_ag - 09-09-2017
(09-09-2017, 09:43)danner Wrote:  ...
Fixed in WeatherDuino Pro2 PLUS WD v3.0_b009
Thanks for your help
Fixed, thanks! :-)
