AuriolDuino Receiver - COM port problems - Printable Version
+-- Forum: AuriolDuino - Receiver for Auriol H13726 Weather Stations (https://www.meteocercal.info/forum/Forum-AuriolDuino-Receiver-for-Auriol-H13726-Weather-Stations)
+--- Forum: AuriolDuino - Hardware (https://www.meteocercal.info/forum/Forum-AuriolDuino-Hardware)
+--- Thread: AuriolDuino Receiver - COM port problems (/Thread-AuriolDuino-Receiver-COM-port-problems)
RE: AuriolDuino Receiver - COM port problems - werk_ag - 04-11-2014
pierrelux
Try to force the install of the attached drivers on your "bricked" FTDI arduino.
They are just a modified version to work with FTDI chips que have the PID changed to 0
Tell us if it worked for you.
RE: AuriolDuino Receiver - COM port problems - pierrelux - 05-11-2014
Thanks for the information, but when I install the driver, I have Windows 7, I have the USB Serial Converter, but when I look to the properties, I have : "Windows can not verify the digital signature of the required drivers for this device. It is possible that a recent hardware or software change has installed a damaged or whose signature file is incorrect, or whether it is malicious software from an unknown source. (Code 52)" (translation from French), and impossible to have a COM Port for the RX board.
I have also seen on internet, that there can be a problem with the Arduino Nano and the FTDI chip. Usually it works but sometimes, particularly when an external power input is used, the FTDI chip inside the Arduino does not want to be detected by computer, if the pin 26 (TEST) of the FTDI Chip is not connected to ground, this is a bug made by the developers of Arduino. The solution is to make a bridge between pin 26 and 25 (AGND) by soldering them together. But for the moment I am waiting for the header female connectors, so I can desolder the Nano board.
RE: AuriolDuino Receiver - COM port problems - pierrelux - 07-11-2014
After many hours of tests, I found finaly the follow solution (working with Windows7):
1. Delete ftdi driver (CDMuninstallerGUI.exe) ,
download from : http://www.ftdichip.com/Support/Utilities.htm
explanation : http://www.ftdichip.com/Support/Utilities/CDM_Uninst_GUI_Readme.html
2. Install the new FTDI driver : CDM v2.12.00 WHQL Certified.exe
3. Download MProg3.5 program from http://www.ftdichip.com/Support/Utilities.htm
4. Unzip and run MProg.exe Arduino Nano connected, and see:
https://www.youtube.com/watch?v=RZH_qGautqM
I start Arduino Ide, my Arduino Nano was connected to COM Port 11.
Then start EasyWeather RS232 Logger : OK,
Start Cumulus : OK
I hope this help
RE: AuriolDuino Receiver - COM port problems - werk_ag - 11-11-2014
pierrelux, thanks for sharing this info, I'm sure it will help a lot of people.
I'm also very glad for you having your system working back again.
RE: AuriolDuino Receiver - COM port problems - hornychz - 14-05-2015
pierrelux, thank you - you helped me ... (I have resolved it about two days ...)
(07-11-2014, 12:22)pierrelux Wrote:  After many hours of tests, I found finaly the follow solution (working with Windows7):
