FO wind sensor pinout - Printable Version
+--- Thread: FO wind sensor pinout (/Thread-FO-wind-sensor-pinout)
RE: FO wind sensor pinout - danner - 14-05-2017
The temp sensor and tx board will be mounted on a pole in the middle of my back yard ~90 feet from my house. I'd just run an outdoor extension cord but mowing around cords is a pain in the rear. I have 2 AGM batteries I sourced from my Dad's electric wheelchair so I'll go with those until they die then I'll get a new one. Wife is already asking too many questions with the thousand little charges here and there for bits.
What do you think of this charge controller? http://www.diysolarforu.com/uploads/7/9/9/7/7997124/ra-25watt-charge-controller.pdf
RE: FO wind sensor pinout - JT118 - 14-05-2017
Seems OK, and should be sufficient to keep up with demands of TX board and FARS.
RE: FO wind sensor pinout - f4aii - 22-10-2017
update links for F0:
mast: http://www.ebay.fr/
wind vane: https://www.maplin.co.uk 9.99£
anemometer: https://www.maplin.co.uk 2.49£
