bad IP adress - Printable Version
+--- Thread: bad IP adress (/thread-1080.html)
RE: bad IP adress - werk_ag - 12-04-2017
(12-04-2017, 15:36)f4aii Wrote:  I came out with an old FONERA that is a sharing router, it works very well.
My router may be capricious.
ESP8266 modules are also capricious with some routers. That is a well know fact, described in many forums.
I have 4 routers at home, the ESP8266 modules work perfectly with three of them (DrayTek, GygaByte, Fonera), but I never managed to make them work reliably with a D-Link G604T
Fonera is a very good router for this kind of things!
RE: bad IP adress - f4aii - 13-04-2017
Yes, FONERA is very good router. I have 2 of them.
[Image: fonera_wifi_router_ssid_1.jpg]
For information to other users who would encounter the same problem, it is a "freebox revolution".
Pour les français: La freebox revolution ne fonctionne pas avec le RX pro 2 plus. Il s'associe difficilement et la transmission des datas vers internet reste bloquée malgré mes différents tests. Avec la Fonera et un vieux Linksys, cela fonctionne du premier coup.
[Image: server-face.jpg]
RE: bad IP adress - f4aii - 21-01-2018
Hello, I have 3 RX stations. I just recovered the one that was at my brother for some changes of the box.
The RX, despite the flash of the latest firmware has retained its old IP address: 192.168.10.10 while it should connect in 192.168.1.x here.
I do not have wifi with this address range at home, or my neighbors.
The identifiers are the good ones because I use the same software on another test RX in my home and which is correctly connected.
The points remain red, so it is not connected.
ESP8266 FW Version: AT+GMR AT version:0.60.0.0(Jan 29 2016 15:10:17) SDK version:1.5.2(7eee54f4) Ai-Thinker Technology Co. Ltd. May 5 2016 17:30:30 OK Mode station OK Join AP success IP: 192.168.10.10 Multiple mux OK Start tcp server at port 80 OK STATUS:2 Set tcp server timout 30 seconds ESP8622 init end
an idea? is it possible to assign a fixed IP in the app?
RX board is V1.3.
thanks.
RE: bad IP adress - werk_ag - 21-01-2018
A better way is assign a fixed IP to a MAC address in your router, this way the router always will attribute the same IP to each specific unit.
RE: bad IP adress - hornychz - 21-01-2018
(21-01-2018, 12:19)f4aii Wrote:  Hello, I have 3 RX stations. I just recovered the one that was at my brother for some changes of the box.
RX board is V1.3.
thanks.
You have something bad ... Maybe your DHCP server? If RX joined to your AP successly, your DHCP server
should allocate any IP address from its range, but RX has still its old IP address ... You could restart: 1) RX unit,
2) DHCP server, 3) WiFi AP unit ... If this does not help, you have to look into the DHCP server log on what's going on.
Good luck.
(And I recommend, like Werk_AG, to assign a fixed IP address in your DHCP server corresponding to the MAC address of the RX unit.)
