What is included in Compact Rx bundle?
Been away for a long time... WeatherDuino has gone from strength to strength! Co-incidentally  I have a SDS011 dust sensor on order
I am interested in the  Pro2 compact RX at this time, but I will be getting a AQM module soon!
The post regarding price and availability of the compact RX states:-
WeatherDuino Pro2 Compact - Bundle 1:  76.90€
1 x WeatherDuino Pro2 Compact
1 x WeatherDuino Pro2 TX v3.12
I know the Rx is supplied complete, but what is supplied in the Tx part, a pcb or an assembled unit?
many thanks
Patrick
(09-04-2019, 09:54)Superpat Wrote: Hi,
many thanks
Patrick
The TX board is supplied with the surface mount 3.3V regulator fitted and a pair of RJ12 sockets (not fitted).
You have to supply all other components which are through hole parts.
All parts should be easy to acquire.
