Software upload issue
I am having a problem uploading the latest Rx build; Error file atached
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v4.1\software\RX software\WeatherDuinoPro2Plus_RX_v410_b008_12122017\WeatherDuinoPro2Plus_RX_v410_b008_12122017.ino:41:0:
sketch\Config_RX_Pro2PLUS.h:44:126: fatal error: _lang/en_GB.h: No such file or directory
#include "_lang/en_GB.h"      // Change the language code according to your preference. Keep "_lang/" and the ".h" at the end
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Jim, you *have* got a subdirectory named _lang (and containing the language files) like this, haven't you??
This version works perfectly for me.
Allan
Attached File(s) Image(s)
P
(12-12-2017, 10:29)AllanG Wrote: Jim, you *have* got a subdirectory named _lang (and containing the language files) like this, haven't you??
Allan
Allan,
I will check shortly, I was surprised to have an issue as the software is usually no problem.
Allan,
Yes I have found the correct file with a _lang sub directory and will try again tomorrow
Hi Werk
I'm having trouble uploading the new update to the WD with the following error : -
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Users\rich2\Documents\Arduino\WeatherDuino_Pro2_PLUS_v4.1_20171211\WeatherDuino_Pro2_PLUS\v4.1\software\WD software\WeatherDuino_Pro2Plus_WD_v4.0_b005\WeatherDuino_Pro2Plus_WD_v4.0_b005.ino:39:18: fatal error: Lang.h: No such file or directory
 #include "Lang.h"
exit status 1
Error compiling for board Arduino Nano.
The folder "_lang.h" is in the directory : -
Hi Rich,
In the hurry of publishing the fix for the issue reported by you I forgot to delete that line of code on the WD software. Please delete it, or download the WeatherDuino Pro2 PLUS software package again.
Allan
Allan,
Allan,
Hi Werk, Allan,
What was the issue was that when I "saved as" my amended Config files with a distinctive name the _lang sub directory was not included; I copied it across and now uploaded fine
I noticed that the software version led is yellow and when checking, the screen says the latest version available is v4.1_b0006 and the installed is v4.1_b0008.
Is this something I can fix locally?
(12-12-2017, 23:42)Barrow4491 Wrote: I noticed that the software version led is yellow and when checking, the screen says the latest version available is v4.1_b0006 and the installed is v4.1_b0008.
Next time the system do a "Latest Version Check" everything will be fine. Info on the Server was updated just a few hours ago.
