Pro2 PLUS Problems compiling latest version of Pro2 Plus Rx Software
Hi All,
I've just downloaded the latest version of the Pro2+ Rx software (P2AT2560_RX_v8.1_b002) and libraries, but i'm not able to compile it and get a few errors. The errors are below and I've attached the verbose output from the Arduino IDE during compilation. Has anyone else had these errors, or am I doing something simple wrong?
Thanks in advance for your help!
Zak
Arduino: 1.8.8 (Windows 10), Board: "Arduino Nano, ATmega328P"
WeatherDuino_P2AT2560_RX_v8.1_b002:428:14: error: 'Serial1' was not declared in this scope
 ESP8266 wifi(Serial1);
Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\Routines.ino: In function 'void B_doubleclick()':
Routines:629:14: error: 'PORTH' was not declared in this scope
   setPortLOW(PORTH, 6); //digitalWrite(TFT_BKL, LOW);
Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\WeatherDuino_P2AT2560_RX_v8.1_b002.ino:129:33: note: in definition of macro 'setPortLOW'
 #define setPortLOW(port, pin) ((port) &= ~(1 << (pin)))
Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\VP.ino: In function 'void cmdDmpaft()':
VP:292:19: error: 'PORTG' was not declared in this scope
       setPortHIGH(PORTG,  1); //digitalWrite(FLASH_CS, HIGH);
Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\WeatherDuino_P2AT2560_RX_v8.1_b002.ino:130:34: note: in definition of macro 'setPortHIGH'
 #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))
VP:306:14: error: 'PORTG' was not declared in this scope
exit status 1
Attached File(s)
.txt   P2AT2560_RX_v8.1_b002 Errors.txt (Size: 146,76 KB / Downloads: 1)
Hello Zak,
I'm afraid you are trying to compile the code for the wrong board.
The Pro2+ software is for a Mega 2560.
Smile
(05-02-2019, 13:58)Werk_AG Wrote:
(05-02-2019, 10:56)Zack_ster Wrote: Zak
Hello Zak,
Doh! - as Homer Simpson would say. Thank you!
