Threads: 1
Hello
I'm finally building my Pro2 plus and discover that I got 2 different BME280
1 with 7 pin ( BME280 adafruite) and one more simple with 6 pin !
On the pcb it's only 4 pin... 3.3 v, gnd, scl, sda
How to proceed ?
regards
jk
Threads: 270
Weather Station: MeteoCercal, Cercal CDV Portugal
(30-04-2020, 17:33)jonnyhk Wrote: Hello
How to proceed ?
regards
jk
Hi jk,
If the sensor you have works in I2C mode, just connect those four pins on the pcb to the corresponding pins on the BME280 sensor module.
SCL, SDA are the standard designation for I2C communication lines. If your sensor module doesn't have those designations, try to ask manufacturer if it works in I2C mode, and what pins to use.
I quick search on the Adafruit BME280 datasheet will show you what pins to use: https://learn.adafruit.com/assets/26693
Threads: 4
(01-05-2020, 04:28)Werk_AG Wrote: (30-04-2020, 17:33)jonnyhk Wrote: Hello
How to proceed ?
regards
jk
Hi jk,
Hello , I engage in this discussion.
I finished building the weatherduino pro 2 receiver with the 4pro wireless display. I immediately noticed that I have problems with the bme280 sensor. When I receive the data from the tx, the 4pro wireless display shows the humidity and external temperature value while the rx does not transmit the data from the bme280. In this case the wireless display shows the temperature value = 0.0 while the atmospheric pressure = - 2147484 mb. I purchased the bme280 sensor from adafruit site and I am sure of the connections and settings made. Anyone have any suggestions to give me. Thank you. Regards.
Threads: 270
You can try using the MultiSpeed_I2C_Scanner.ino utility (included in the software package) to check if the sensor is correctly detected on the I2C bus.
The BME280 should be at address 0x76
Threads: 4
(15-06-2020, 21:01)Werk_AG Wrote: Hi,
I used the i2c scanner and i found the following adresses:
0x50
0x57 RTC module
0x68 RTC modale
0x77 BME280
Is there something wrong?
Thank you
Threads: 4
(16-06-2020, 18:25)bombenm Wrote: (15-06-2020, 21:01)Werk_AG Wrote: Hi,
0x50
0x57 RTC module
0x68 RTC modale
0x77 BME280
Thank you
Line 84 and line 90 of Config_option.h tab has been set to 0 for the BME280 sensor.
Threads: 270
Seems your Adafruit BME280 module isn't configured to use the default address which is 0x76
Please check Adafruit documentation, so see how to change it from 0x77 to 0x76
EDIT
From Adafruit documentation:
Quote:By default, the i2c address is 0x77. If you add a jumper from SDO to GND, the address will change to 0x76.
Threads: 4
(16-06-2020, 21:07)Werk_AG Wrote: Hi,
EDIT
Ok, I Will try to read the adafrut documentation in order to change the adress.
I will keep you informed.
thanks
Threads: 270
This module, is widely available on eBay, its a lot cheap, and doesn't require any change on the address, as by default it uses the standard BME280 address of 0x76
Threads: 4
Hi
You were right.
Conecting the SD0 pin to GND ,the address changes to 0x76. Now it works.
Thank you for your help.
regards
