This forum uses cookies
  • 0 Votes - 0 Average
Night cloud cover
(03-02-2019, 08:49)JT118 Wrote:
(03-02-2019, 08:37)philipgm Wrote:
(03-02-2019, 05:02)Werk_AG Wrote:
(02-02-2019, 07:12)JT118 Wrote: Weather Display does work with Weatherduino ...
During my tests with Weather Display, I only found a difficulty: I haven't found a way to use a multiplier for the rain data, so it only gives correct rain readings when used with a rain gauge which have 0.2mm per tip.
However, may there is a way that I hasn't managed to found.
I think the setting could be done on the:
'Universal Setup' page. On the 'Rainfall Setup' area.
Just on the left in the Rain Offset area.
In the second box, I think you could put 1.4 for the Fine Offset rain gauge.
I haven't tried it but I think that would work.
Cheers
Philip
We must have been posting at the same time !
Great minds think alike ?
