AQM II question
Hi Werk
Does the AQM II require the RF module to transmit to a receiver such as the Pro2 Compact, or does that occur via the wifi udp stream?
Many thanks
Colin
Hello Colin,
Currently yes.
At some point in the future that feature may be added into the Pro2 Compact receiver software.
Werk_Ag
Ok, no problem at all Smile
I'm going to look at retrofitting my existing AQM with a Wemos to take advantage of the wifi. I have devised a method to send the AQ data to Weewx using UDP. The code is currently running on the receiver but I could easily move it to the AQM with the Wemos. They are $10 NZ each, so easy to buy and have a play with.
Many thanks
Colin
