01-06-2019, 05:13
I am getting the following message when trying to load the software on my new AQM. What im I doing wrong??
WeatherDuino_AQM_ESP8266_ASK_v120_b006:68: error: 'D6' was not declared in this scope
#define DUST_RX D6 // D6 - GPIO12
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:224:30: note: in expansion of macro 'DUST_RX'
SoftwareSerial Dust_Serial(DUST_RX, -1); // define serial for PMS7003 sensor
WeatherDuino_AQM_ESP8266_ASK_v120_b006:70: error: 'D7' was not declared in this scope
#define CO2_RX D7 // D7 - GPIO13
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:231:29: note: in expansion of macro 'CO2_RX'
SoftwareSerial CO2_Serial(CO2_RX, CO2_TX); // define serial for CO2 sensor
WeatherDuino_AQM_ESP8266_ASK_v120_b006:71: error: 'D5' was not declared in this scope
#define CO2_TX D5 // D5 - GPIO14
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:231:37: note: in expansion of macro 'CO2_TX'
WeatherDuino_AQM_ESP8266_ASK_v120_b006:66: error: 'D0' was not declared in this scope
#define TXData_PIN D0 // D0 - GPIO16
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:234:25: note: in expansion of macro 'TXData_PIN'
RH_ASK ask433(1000, -1, TXData_PIN, -1); // ESP8266: do not use pin 11
WeatherDuino_AQM_ESP8266_ASK_v120_b006:237: error: 'D2' was not declared in this scope
SH1106 display(OLED_ADDRESS, D2, D1);
WeatherDuino_AQM_ESP8266_ASK_v120_b006:237: error: 'D1' was not declared in this scope
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino: In function 'void setup()':
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:355:11: note: in expansion of macro 'TXData_PIN'
pinMode(TXData_PIN, OUTPUT);
WeatherDuino_AQM_ESP8266_ASK_v120_b006:67: error: 'D4' was not declared in this scope
#define PMS7003_SetPin D4
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\WeatherDuino_AQM_ESP8266_ASK_v120_b006.ino:359:11: note: in expansion of macro 'PMS7003_SetPin'
pinMode(PMS7003_SetPin, OUTPUT);
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\Functions.ino: In function 'void WakeUpDustSensor()':
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\Functions.ino:54:18: note: in expansion of macro 'PMS7003_SetPin'
digitalWrite(PMS7003_SetPin, HIGH); // PMS7003 Wakeup the sensor - turns the fan ON
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\PMS7003.ino: In function 'void read_PMS7003()':
C:\Users\JBA\Documents\Arduino\WeatherDuino_AQM_II\v120\software\WeatherDuino_AQM_ESP8266_ASK_v120_b006\PMS7003.ino:39:16: note: in expansion of macro 'PMS7003_SetPin'
digitalWrite(PMS7003_SetPin, LOW); // Put the sensor to sleep and turn the fan OFF
Using library TimezoneESP8266 in folder: C:\Users\JBA\Documents\Arduino\libraries\TimezoneESP8266 (legacy)
Using library Time at version 1.5 in folder: C:\Users\JBA\Documents\Arduino\libraries\Time
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi
Using library ESP8266mDNS in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266mDNS (legacy)
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WebServer
Using library ESP8266HTTPClient at version 1.1 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266HTTPClient
Using library ArduinoOTA at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ArduinoOTA
Using library RadioHead_TeensyVersion in folder: C:\Users\JBA\Documents\Arduino\libraries\RadioHead_TeensyVersion (legacy)
Using library SPI at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\Wire
Using library esp8266-OLED-SSD1306 at version 3.2.7 in folder: C:\Users\JBA\Documents\Arduino\libraries\esp8266-OLED-SSD1306
Using library Timer in folder: C:\Users\JBA\Documents\Arduino\libraries\Timer (legacy)
Using library Adafruit_SHT31 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31
Using library HTU21D in folder: C:\Users\JBA\Documents\Arduino\libraries\HTU21D (legacy)
Using library SoftwareSerial at version 1.0 in folder: C:\Users\JBA\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\SoftwareSerial
Using library ArduinoJson at version 5.13.2 in folder: C:\Users\JBA\Documents\Arduino\libraries\ArduinoJson
exit status 1
