Pro2 PLUS Wireless Display mphh
Hi Werk
Don't know if anyone else who uses the wireless display has noticed, but if you are using mph as the wind units then after the initial startup where it displays km/h the wind units will change to mphh as below.
To get rid of this I have added a space in the code for the wind units, changed "mph" to "mph "
Hi Rich,
Seems you discovered a bug, and the solution!
A space should be added for the other units too.
Correction will be included on next software release.
